URGENT HELP NEEDED. Xsara won't start?
Results 1 to 9 of 9
    Fellow Frogger! DJ-Studd's Avatar
    Apr 2003
    Victoria, Australia
    548
    Icon4 URGENT HELP NEEDED. Xsara won't start?
    Hi Guys,
    I'm having a problem starting my Xsara.
    Drop up, parked at my in-law's place then went inside for 40 minutes. Came back out, tried to start her and the starter moter makes a quick click, then all of the dials flutter like crazy and the wipers move up a few inches, with dinging noises and crazy stuff.
    Help, the car won't start!
    I've tried removing the power to the car a few times to reset the ECU, but it has made no difference. Jump starting didn't do anything, same result as above.
    Heeeelp!
    Ta.
    -- DJ
    Edit: it also at one point said that there was an airbag fault when I put the ignition on, but I haven't gotten that to appear again.
    CitroŽn Tragic UFO's Avatar
    9,807
    Could be as simple as a flat battery. Otherwise call RACV whatever wherever you are
    16,743
    Yep,
    battery or battery terminals. That's how modern batteries die (ie: no warning).
    Tadpole Alan Macoustra's Avatar
    Jul 2005
    18
    Default Xsara won`t start.
    Iŗm afraid Shane`s on the right track. Possible dead cell in battery,check alternator drive belt isn`t broken & is adjusted too proper tension. Don`t forget too check charge rate when you get mobile again.
    To Ride Is Human To Glide Is Divine
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    If I read this correctly he's already tried to jump start it so it's highly unlikely it'll be a battery.
    I'd siuspect a short in the starter or solenoid possibly or maybe even a starter switch/ignition switch failure.
    Alan S
    Apr 2003
    Victoria, Australia
    548
    Arr...
    it was the battery.
    The battery, although only 3.5 years old, had completely carked it and thus wasn't completing the circuit...
    New battery and off she goes
    Thanks guys
    -- DJ
    Nov 2002
    Yarrabilba, Queensland
    2,759
    Quote Originally Posted by DJ-Studd
    Arr...
    it was the battery.
    Thanks guys
    -- DJ
    only 3.5 years old I'd not scof at that, the life span these days would be lucky to be 2 years average.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    1000+ Posts TroyO's Avatar
    2,514
    Quote Originally Posted by HONG KONG PUGGY
    We got 5 years out of the original battery on the 1.8L Xsara. It will be interesting to see if we can get similar life span out of the replacement one.
    Troy.
    Member dom19's Avatar
    Sep 2005
    Lobethal
    87
    Last battery I bought was a Caterpillar maintennance free. Ran it for two years in a 4 cyl. Tarago then transferred it to my Rover V8 for the last 3 years. Still turned her over several times before firing up after a week of no activity last week when I sold the car. These batteries came with a 5 year pro rata warranty when I bought it but I don't know if that still applies. Best battery I've bought in years. Still doesn't beat the Hungarian battery that was in a Lada a family member owned, 7 years of continous service. Shame the Lada couldn't match the battery!!!
    Dom
    Xantia SX 1997
    Toyota Spacia 2000
