Quick paint job anyone ???? - Page 4
Page 4 of 11 First 12345678 ... Last
Results 76 to 100 of 271
  1. #76
    Bristol/England!
    1,487
    Another 1.5hours last night .... 14.5hours now (SWMBO is starting to get really p!$$ed with me ).
    Quote Originally Posted by smiffy1071
    If you have a partner, you will need thick skin too, as they will be nagging at you to stop wasting your money and time, and go buy a newer car!
    It's at that point that I reccomend a sudden spell of
    deafness helps
    See what I mean? john s
  2. #77
    16,156
    Removing the picnic shelf is quite easy ... Once you know how ...
    The four holes you see in the spoiler here... If you dig the muck out of them you will find the heads to 4 philips head screws.
    I found though they all unscrewed, I couldn't pull them out. Unfortunatly there just a long self tapper.
    This means they will still hold the spoiler in place.
    These screws combined with:
    The plastic clips shown at the top edge of the bootlid here, hold the main portion of the spoiler down.
    The spoiler is also retained by the bootlid hinges themselves:
    So you need to unbolt the boot and have it flopping around while you attempt to get the spoiler off.
    Once you unscrew all the screws and unbolt the boot lid, if your like me and couldn't extract the screws, you will need try pry the back edge of the spoiler up (gently so you don't smash the plastic retaining bits). In my case the screw popped out.
    This is what the screws are screwed into.
    I didn't notice at the time but I actually broke the tags that retain the front middle part of the spoiler
    This shouldn't be an issue when it comes to time to re-mount the spoiler. I'll just hold this front edge down with double sided tape.
    Now I had a bootlid the was retained by just the bootlid hinges.
    This is where I got stuck... It appears the plastic incapsulates the boot hinges. It looks like the plastic that encapsulates the boot hinge (holding the spoiler) is a plastic slide ... That you will destroy attempting to remove ... smashing the plastic.
    In desperation I finally decided I'd have to smash the plastic in order to remove the plastic clips. At this time I found it's actually 4 plastic clips that will come out without damage:
    The plastic base you can (carefully) pry out is this:
    The plastic boot brackets are retained by small rivets attached to the boot skin
    The plastic windows just slide outof there cuttouts once the spoiler is off.
  3. #78
    16,156
    Alrighty,
    thursday night I fixed the roof ...
    There wasn't to many 'highs' that needed bashing down, so it only took a couple of trys to get this right.
    All done ... Roof just needs a hit with the D/A sander before I hit it with the oneshot.
  4. #79
    16,156
    Last night I managed an hour tinkering in the shed. Upto 15.5hours now.
    I removed the door handles and locks in readiness for spray the oneshot.
    Removing the door handles is quite easy:
    Remove the 3 bolts that retain the handle (allan key bolts)
    Just slide you hand around the back of the doortrims, releasing (but hopefully not breaking) the plastic clips.
    These two nuts retain the handle. Once you remove them the handle will just slide off (you can still use the doors just by poking a finger in the hole to activate the door lock).
    The keylock just has a 'U' shaped bit of metal retaining it. The metal wire down to activate the lock just unsnaps out of the plastic clip
    Look what I spotted when I removed the passenger front door lock & handle ....
    Some @sshole has tried to break into the car in the past by hammering at the lock (most likely by hammering a screwdriver into the lock). I had to straighten the metal as you can see.
    Also I found rust in the lowest corner of the back door ... a bloody rust bubble ... I thought this car was good for rust
    Luckily it appears to be rusty from the outside, I hit it with the wirebrush and there is nothing there that needs to be fixed. It appears a stonechip has allowed water behind the paint (phew ).
    Under the top door trims there is a type of glue (bugger it). It really tough, almost like a ceramic or epoxy type glue. It took 15minutes to scrape a tiny bit off even using a razor blade ... So I quickly gave up and hit it with the wire brush in the grinder, then feathered the edges with the D/A sander.
  5. #80
    Bristol/England!
    1,487
    The paint finish for the rear window trims, and the bootlid, is a satin finish. Not gloss, or matt. Hope that is available near you, john s
  6. #81
    Don't remind me!
    16,610
    The hard glue you describe would almost certainly be a polyurethane. Gorilla Glue might be the closest you can get. Selleys' Urethane Bond used to be similar but they changed it...
    Satin and matt - from the Dulon mixing guide:
    Matt: 100 parts colour/clearcoat, 75 parts flattener
    Low Gloss: 100 parts colour/clearcoat, 60 parts flattener
    Semi Gloss: 100 parts colour/clearcoat, 40 parts flattener
    Or you can wing it and mix in unperfumed plain talc to your colour or clearcoat...
  7. #82
    16,156
    Thanks Adam,
    yeah I thought the glue was some sort of glue (as opposed to tape).
    I managed to spend probably 4.0hours out there today. 19.5hours were upto now.
    Gee's I hate masking up ... it's so tedious, and I always miss somewhere and have overspray to clean off.
    I decided to wet rub some the guard ... My hands feel really great now ...
    The dulon oneshot is brilliant stuff ... I wouldn't have a hope in hell of getting anything even close to straight without it ...
    Remember the bonnet ....
    You just wetrub the oneshot with big circles and lots of water ...
    It'll turn like this ...
    Just keep on sanding in big circles ... eventually you'll get to just a few dots of guide coat
    Here's that repaired area taken with a 500watt light shining across it ...
    Yep that oneshot is amazing stuff
    Hopefully tomorrow I'll give the whole car (except bootlid & bumpers of course) a few heavy coats of oneshot so I can drive the car monday.
  8. #83
    Don't remind me!
    16,610
    A friend swears by the 3M panel bonding adhesive for reattach jobs like those strips, but I don't know what cartridges it comes in here. Probably one of those "systems" where it's not viable to buy (typical). If someone has the tailend of a Fusor cartride, that would be OK also for you.
    Get a roll of Cam-Poly plastic masking. You edge up the glass or panels in tape, slice off bulk plastic, and go to town. The roll opens to about 4m wide, and IIRC it's 100m long. You need to change it every stage of paint, or dried paint will blow off it with air pressure and settle into the wet coats. When you are making domestic amends by renovating the kitchen and bathroom, the leftover roll will come into play for excellent dust control.
    Do you have grey (automotive) Scotchbrite? It's great for a final whizz-over with water if you wet-sanded some areas then spot-primed too close nearby. Picks off dust and dags nicely.
    I never recommend this but... Heating thermosplastic paints in a hot water bath before spraying thins them out, gives more bite into the substrate, and promotes faster through drying. It's how a lot of old automotive parts were painted; warm the part, heat the paint and one or two coats of black nitro saw it good. I can tell you it works just great with modern acrylic primers too. So if you get a rainy spell...
  9. #84
    Moderator vivid's Avatar
    parallel 43į south
    1,804
    Hey Shane, driveshaft fixed... I'll be up to give you a hand tomorrow.
    Looks like heaps of progress, and triumph... looks great.
    Maybe we can add some photos from the 16 in there tomorrow.
    I'll try and find your number to give you a call, otherwise ill PM you in the morning. Should be there around lunch.
    Ill have the trailer so I'll bring my uber-cheap compressor to test out some tools.
    David.
  10. #85
    16,156
    Hi Adam,
    thanks for the advice ... Without a booth I will not be painting in cold weather, I'd end up with moisture in it for sure. My grandfather said he used to have a guy that painted dashed and cars ... with a brush ... He would heat the pot of paint to the perfect temperature and paint it on ... Apparantly it was the best job you could possibly get, and it was impossible to tell it was applied with a brush
    I already have a roll of 3M tape here for the door strips (probably not enough). The local auto paint shop really is very good here, they only sell good quaility stuff. A lot of it is either Dulon (paints) and most of there cutters/polishes/tape/paper/etc... is 3M. I have had nothing but brilliant results using 3M products.
    About 5years ago I painted a very tired old ID19... Unfortunatly it didn't every look hugely great as the panel fit was a dogs breakfast that I never did get even close to right ... However here one of it's back guards
    That's Dulon Midnight black, clear that's then wetrubbed with 800 ... then 1200 grit paper. The bit you see has been hit with the buffing machine with 3M cutters, then 3M micro-fine cutters ... That's the shed roof you can see if the photo and the sky ... Bloody awesome paint ... pitty it's finish doesn't last for sh!t
    Look forward to hearing from you David.
  11. #86
    16,156
    I spent another 1.5hours today ... The whole car has oneshot on it now (except bootlid, bumpers and fuel flap of course). Upto 21hours now.
    Then ripped all the paper off and refitted the rear bumper and tailights so I can drive it to work tomorrow.
    This is how strong the aussie sun is... The black tape on the rear window surround .... It's lifted and peeled I'll have to remove it and paint these satin black too.
  12. #87
    Hobart
    1,479
    Hi Shane,
    This is a really great thread, we are about to get into the body work on the 204 and it's great to have this informatin...
    Thank you very much for taking the time to log it..
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
  13. #88
    16,156
    Hi Ben
    yeah I'm trying to keep a log of time that goes into these things (I'm sure it'll put off the "We can paint it in a weekend" brigade)
    Another 1.5hours tonight, I've wet rubbed both front guards completely now.
    Those rear window surrounds ... That black tape maybe lifting ... But where it's not lifted, it's stuck down bloody tightly... I figured if the aussie sun caused it to lift ... So will a heat gun, so I heated it up to find once it's really hot it'll scrape off (that'll be some smelly fun for later).
  14. #89
    Bristol/England!
    1,487
    I don't think you can put that tape lifting just down to sun exposure, you remember the turbo car I scrapped, that had the tape lifting aswell.
    Luckily for me, my car has the tape intact, so that's one less job.
    Do you think there might be the chance of getting those rear spats to fit?
    Maybe the lower lip might fit if you grind it away a little? john s
  15. #90
    16,156
    Hmm,
    not sure about the rear spats. I'll have to check...
    seeya
  16. #91
    16,156
    Hi Smiffy,
    I have tried to get the spats to fit ... The problem is the tyres fitted to it are very wide for the size, and have raised letters... The spats are quite soft plastic, I just cut the lip off roughly with the jigsaw then filed it level.
    The spats still touch slightly (even after removing the lip). I've left them in place. I'll drive the car for a couple of weeks and see how it goes with them in place. I'll paint them up if there ok.
    Another 1.5hours tonight to modify the spats and wet rub more of the bonnet. Upto 22.5hours now.
  17. #92
    Fellow Frogger! nos205gti's Avatar
    Rozelle
    333
    Hi Smiffy,
    that is excellent job
  18. #93
    Bristol/England!
    1,487
    Hi Smiffy,
    That is basically how Neil got them to fit on CGAT. Good to hear they might see light of day once again. john s
  19. #94
    16,156
    The problem is I still need about 1mm clearance at the back edge... Not much but quite a lot in reality. What I'll try is cutting another slot in the bumper for the back lower edge of the spat to sit in. They do look a lot better with the spats in place. The front edge of the spat is screwed in, the back edge slots into the bumper. It will no harm the bumper in any way if I cut another slot for the spat.
  20. #95
    Fellow Frogger! Boyracer's Avatar
    Sydney South
    601
    This is a fantastic thread! Makes me want to go out and get myself a project!
    Look at all the views. Shane, there's a lot of folk looking over your shoulder while you're working. :-)
    Michael
    ____________________________
    Citroen Car Club of NSW - Member
    1974 Citroen DS23 non Pallas BW Auto/Carby with Air-conditioning [AC640 Delta Blue]
    1972 Citroen DS21 5SPD EFI Pallas [AC088 Blanc Meije]
    2012 Citroen C5 Exclusive 3.0L Auto Diesel [Noir Perla Nera]
  21. #96
    Fellow Frogger! Ren25's Avatar
    Dec 2002
    Perth
    294
    Yeah Shane, you're going to have a lot to answer for. I for one, have started stripping out my old Guzzi Le Mans on the strength of it! There's a restorer lurking in all of us, just waiting to escape. Keep up the good work.
    Armageddon was yesterday
    Today we have a problem
    2000 406 Hdi X 3
    2003 307 Hdi
  22. #97
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    A word to the wise with the spats; they were taken off my silver car due to the Delta mags that were fitted and for 99% of the time it was no hassle, then one day............I was going around the Bunya Mountains at a fairly heavy rate of knots and as I went into righthanders a bit hard, a strange noise seemed to come from the rear of the car. Lookingthrough the outside mirror I swore I could see blue smoke but as I couldn't smell it I just backed off a bit in case it may have been oil. However, when I arrived at my destination I admired my almost new Pirellis and at the same time went looking for the source of the smoke and discovered I now had smooth walled "no name" Pirellis.
    Due to the angle of lean when cornered hard, the wheel arches rolled far enough around to actually scrape the lettering, so I would guess you'll need more than 1mm tolerance.
    Alan S
  23. #98
    16,156
    Alan S
    Thanks Alan,
    In this case it's not such a huge issue ................................ 'Cos the spats are rather soft plastic (no rust here ).
    I think the worst that could happen is your tyre would wear the edge off the spat
    Seriously though, It's only the very back edge that's giving me problems, mounting the lower edge 1mm further out should give enough clearance (I hope ).
    seeya
  24. #99
    16,156
    Quote Originally Posted by Ren25
    Hi Guys,
    we haven't even seen the finished product yet ................ We may well wish I'd never started 'cos it comes out looking worse than before
  25. #100
    Bristol/England!
    1,487
    Shane, why are you doubting yourself? you look like you are doing things in a methodical order, and paying attention to detail. you are being carefull to do prep work as well as you possibly can. i'm sure you will have a car to be very proud of when you have finished. I just wish it were warmer here so I could get the enthusiasm to start doing the same job to my car!
    john s
