Bloke's Xantia Woes
Results 1 to 11 of 11
    Member Jon Wood's Avatar
    Feb 2002
    Swindon UK
    75
    Bloke's Xantia Woes
    Just found this, bloke so fed up with his Xantia that he creates website to slag the thing off and advise anyone not to buy a Citroen!
    <a href="http://www.citroendont.fsnet.co.uk/" target="_blank">http://www.citroendont.fsnet.co.uk/</a>
    BX 1.7TD TZD 1993
    Berlingo Multispace 2.0 HDi 2004
    Sense Pug307's Avatar
    Australia
    4,355
    Well,
    <a href="http://www.whatcar.com/news/report/data.asp?article=360&cat=2" target="_blank">Citroen - No 20/22</a>
    Seems the less a Citroen, a Citroen is, the more reliable it is.
    Justin
    Peugeot 307 XS 1.6
    Rendezvous Adelaide 2005
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Just out of curiosity, how bloody stupid would you have to be to keep using a door that was obviously seizing until it seized shut?
    Some of these problems may be genuine to a point, but with all due respects this bod has got to be a right tosser hasn't he? He seems to have a problem distinguishing faulty workmanship with incompetent or slip shod maintenance <img src="graemlins/tongue.gif" border="0" alt="[Tongue]" />
    As they say; some mothers do 'ave 'em <img src="graemlins/clown.gif" border="0" alt="[Clown]" /> <img src="graemlins/tongue.gif" border="0" alt="[Tongue]" />
    Alan S
    Feb 2002
    Swindon UK
    75
    I did sort of get the feeling that to become so pissed off with your car you build a website decscribing everything thats wrong with it, then you must feel quite strongly. He does not say how many miles the Xantia covered, but the broken clutch cable clip is always caused by a worn out heavy clucth, the clip is Ok for the task otherwise.
    As for the door falling off, well, it must have given some warning signs.
    I personally found it all quite amusing. Mind you, its not my car!!!!
    [ 05 April 2002: Message edited by: Jon Wood ]</p>
    BX 1.7TD TZD 1993
    1000+ Posts Bruce H's Avatar
    Apr 2001
    1,211
    Had to do the mentioned front door hinge repair on the BX estate I owned when I bought it (at 130000ks app). Vaguely recall someone telling me it was a common BX fault, but whether that comment applied to all models or only the wagons (built at a different plant) I don't know. BX owners, go out and look at your driver's door top hinge and see if there's fracturing around it.
    As for the Pug like Cits being more reliable, it's rot. The things that let down the Xantia and XM suspension have been the electrics AFAIK, the same thing that constantly let down the reliability of my AX (read a 205/ Saxo predecessor). The only other problems I had with the AX were based on the (Pug-like) brake-fluid filled brakes leaking through their seals. Why Citroen ever thought the move to brake fluid in the C5 was a forward move I'll never know!
    Bruce H
    Now 99 Xantia SX x2; 96 Xantia SX; 76 GS Club Estate x2; 76 GS Club; 74 GS Club; 88 VW T3 Reimo
    Before: AX Gti; BX 19TRi Estate; CX 2200 Super & Pallas; CX2400 Pallas; CX 2400ie Prestige auto; DS3 DStyle; GS Pallas; GSA Club; Xantia Image Estate; Xantia Exclusive; Xsara VTR R4; 1.4 Special Estate; Virage; R16TS
    Contact for the Australian Citroen GS GSA and Birotor Register http://australiancitroengsgsaandbiro...com/index.html
    Feb 2001
    Romsey, Victoria, Australia
    4,819
    I can think of lots of words to describe this bloke but unfortunatly none are printable, but really, a bit of common sense please. If you bought a car you considered a lemon would you
    A/ Trade it in straight away while it was still worth something, or,
    B/ Make up a website bagging the car so much that your car and everyone else's car is worth absolutly nothing.
    There's no such thing as the perfect car and every manufacturer has been known to build a dud, so if your unlucky enough to buy one of these duds the smart people would just get rid of it and get on with life, anyway thats my opinion, by the way, I haven't read this bloke site because I can't be bothered waisting my time on morons.
    David.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    NSW
    4,917
    I saw this website also a while ago and read it and thought it was funny. I decided to buy a Renault 19 instead of a Xantia but it was only because i was afraid if those electrics and i was was also told by someone that when the suspension goes the steering goes and all other things also. I am always worried about the suspension on citroens....I would like to buy an auto BX however..or even an automatic CX
    16,370
    Hi Danial,
    yeah, you've been speaking to poeple that have never worked on or owned a citroen (or have owned one and been ripped off at every oportunity because of the 'hydraulics' being bad ).
    Basicly 95% of citroens will be dead & gone before the hydraulics die. I bought an old 63 brake fluid ID19 that had been sitting under a tree for years. It didn't run and the hydraulics didn't work.
    I cleaned the brake fluid resevoir, changed the fluid and the car lifted & brakes worked. Cleaned the black sludge from the height correctors (being 40years old and no regular fluid changes had caused this). Then I've started driving it... No suspension problems, no brake problems.... etc...
    If you ever hear someone say how unreliable citroen suspensions are, especialy if they are a mechanic you'll know straight away there talking bullshit and know nothing about what they speak of evil evil
    BX's do have problems with the front strut seals going, but hey it's cheaper to fix that than to replace shockers all the time :p CX's don't really have any common problems other than idiots servicing (or not) servicing them
    Fellow Frogger! Paul Smith's Avatar
    Camperdown, NSW, Australia
    624
    Hi Daniel,
    The BX19TRI Auto is not a bad car (ask Craig - he just traded his on the XM) - much better then the woefully geared BX16TRS. A reasonable one should be around the 4K mark, more for well kept ones. Look out for the state of the gearbox, as a neglected one will cost more than the car is worth to fix - it is a ZF.
    Unless you are a masochist with a fetish for interesting electrical gremlins steer clear of early CXs - they are lovely cars, but!! The sagas of C-Matics are too legion to recount.
    That said I know of people who have paid $500 for a car 3 years ago and not spent a penny, and it is still going strong.
    The later CX2500s are much better sorted - the ZF auto is very solid, and they go pretty well - not much can beat them as an open road point to point car. Just remember that it is a big car - long as a Holden Statesman, and not really a town car. Good autos fetch between $5-7K, more for the best.
    It is reaching the point now where CXs are getting rarer than Ds - people don't see the collectible value, and the complications of owning one put so many people off.
    Don't be put off by the hydraulics of a Citroen - that, if maintained properly - ie not neglected, is generally vey reliable - catastrophic failures are incredibly rare - you have to ignore something that is not right for quite a while to have that happen. I have had more brake problems with our family's 25 yr old 230 Benz than with any of my Citroens.
    Paul
    Paul Smith
    1974 DS23 EFI BW Auto
    1974 G Special 1220
    http://www.simplicitas.com.au
    16,370
    OK,ok,
    CX's don't have any common 'hydraulic' problems. 95% of problems you'll have with a CX is dodgy wiring, dodgy wiring, and bad wiring
    All in all very simple & easy to fix for a DIY!
    Local Tyrant gibgib's Avatar
    Mar 2000
    Sunshine Coast, Queensland
    3,515
    Sorry to bring this one back up.
    I noticed there is a new newsgroup on the dejanews service called free.autos.citroen (there's a Renault one now too).
    You'd think Citroen would take customer service more serious
    Taken from that newsgroup:
    Hello all you Citroen owners
    By now you will have probably heard about my site <a href="http://www.thefergs.freeserve.co.uk" target="_blank">http://www.thefergs.freeserve.co.uk</a> and my problems with my C5.
    I would like to clarify things....
    I love the car - big , powerful and I think good looking
    The reliability I have experienced is BAD
    Citroen have not fixed my faults to my satisfaction
    My dealer has test driven - and passsed my car - when it had faulty steering and faulty suspension - not very good.
    If Citroen iron out the problems - then I will sing its praises.
    I still have faults - which the dealer says he can do nothing
    So now you all know how I feel about this car. If you have a C5 and its performing well - then great. I just want my car replaced.
    regards
    Graham Ferguson
    Hi Graham
    Stick to your guns - one of the girls that I work with has had a load
    of hassle with the brakes on her brand new Saxo siezing.
    She refused to drive the car on safety grounds, Citroen claimed that
    the car was safe, even though they couldn't explain the brake problem.
    Car now taken back by Citroen and full reimbursement made - she now
    has a Renault!
    Steve
    Whitley Bay - North East Coast of England
    I had problems with a Saxo and a bad dealer, I have had a few niggles with
    the Xsara and another bad dealer. They tend to lie and do as little work as
    possible. Why not keep booking the car in for repair work (ensuring you get
    a courtesy car) and refuse to give them their car keys back until they fix
    your car correctly. Ring the manager frequently, speak to him, threaten him
    with solicitors and contact Citroen UK. That should work in my experience.
    Refuse to take your car back when it has not been fixed correctly. If all
    else fails, make a poster with the cars faults and dealer problems and park
    your car outside with the poster. I have seen it done before. I guess that
    should make them work properly.
    Ben
