Fault codes for Bosch MonoMotronic MA3.0
Results 1 to 8 of 8
    Fellow Frogger! AxGT's Avatar
    Apr 2001
    294
    Hey guys - im having a bit of trouble with my AX, as i will be driving along, and occasionally it will cut out, and be quite hard to start again. when this happens, i get a check engine light. I was just wondering if anyone had a list of the fault codes for the injection computer (Monomotronic MA3.0) and the procedure to extract them
    AxGT
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    This any help mate??http://www.vectorbd.com/peugeot/files/405ecu.pdf
    Alan S
    Apr 2001
    294
    Thanks alan, but that ecu is pretty different to mine - i may have to go down to euroserve and get them to hook it up to their test - anyone got any idea how much this should cost?
    6,248
    Hi AxGT,
    I had a look in my Bosch Fuel Injection and Engine Management manual and it seems that with the symptoms you described it could be one of five things. Probably best in the long run that you do connect it to a diagnostic machine. One thing; there are plenty of independent places that have the Bosch diagnostic analyser (even non-French car places) so shop around - you might find one that will do it for nothing. Look for the Bosch logo...
    Stuey
    2003 PEUGEOT 206 GTi
    Apr 2001
    294
    Cheers Stuey, any chance on some leads
    Another thing ive noticed is that it only happens when the engine is still cool
    like about 70 degrees ( about half way on the gauge) and below
    any higher than that and it runs fine - thinking it could be a temperature sensor ?
    AxGT
    6,248
    Ax,
    The manual doesn't specifically cover Monotronic, but states that the principles in the manual apply to it.
    Most of the troubleshooting guide says things like 'faulty air sensor' and 'insufficient fuel pressure' for cutting out and hard cold starting, which is useless really. BUT, the fact that it's only happening cold narrows it down a bit, as your problem occurs in the warm up phase when the system is meant to be injecting more fuel.
    The only thing that's really easy to test is the temperature sensor.
    Assuming yours is the electronic injector type, you can test the temperature sensor by removing it and immersing it in heated water. At 20C it should have a resistance of 2000-3000 ohms and at 80C it should be 250-400 ohms.
    If you've got a separate injector for cold starting, it could be this too - check the connections and the injector for cleanliness.
    Sorry I couldn't be more specific.
    Stuey
    Apr 2001
    294
    Thanks mate
    ill give that a burl
    AxGT
    con
    con is offline
    sydney, nsw, australia
    503
    straight from the "Peugeot-L" list: have a look at
    http://bmw.pp.ru/docs/
    con....
