Xantia Fuel economy
Results 1 to 25 of 46
    16,424
    Default Xantia Fuel economy
    Out of interest, what sort of fuel economy do you guys get out of you Xantias.
    Last weekend I went to Mildura and back (about 1000kms) mostly highway and averaged 32mpg ... I would have been hoping for high 30's to low 40's. This was with the cruise control set to 110km/h and the air-con on.
    Now driving there and back in the CX 2500 GTi Turbo consistantly returns 34mpg .... However it doesn't have air-con or cruise.... But still I'd expect a Xantia with a fraction of the power and speed to return much better fuel economy than a 20year old turbo charged CX
    the car is an 8valve slugomatic. Are others getting considerably better than this ??
    Fellow Frogger! PSvensson's Avatar
    Silverwater
    164
    Around the city I find them to be very firsty for a 4 cylinder,
    between 9-13L per 100km
    highway is much better more like 7.5-8L
    take it into account mines a manual too and im a bit of a lead foot
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,928
    Shane,
    We get about 10l per 100km out of our Xantia around town so long as the traffic is not too bad and about 7-8L per 100km on the highway in similar conditions to your trip. However, mine is a 16 valve manual which does have hight compression than an 8 valver.
    Your auto should be operating with the torque converter locked up at that speed so it being an auto should not be a great influence I would have thought. Did it feel like it was locked up?
    What sort of revs does an auto do at 110km/kr? Our manual does about 3200 rpm at that speed in Fifth Gear.
    What sort of consumption do you get around town?
    Was there a big headwind, no roofrack with stuff on top I presume.
    Maybe you need to get the O2 sensor performance / mixture checked.
    Where you using PULP or better petrol?
    Does your ECU light go out as soon as engine fires?
    Ken W
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    I get around 9 - 10L/100 klms around town and about 7.5 on a trip although I did once get 6.8 over a couple of hundred klms using Optimax.
    Worst consumption I ever got was when I tried it on standard ULP although I filled up on 95 octane the other week and was pleasantly surprised by the results.
    Alan S
    Fellow Frogger! Clogzz's Avatar
    Mar 2005
    Sydney 2087
    189
    Xantia 2.0i 8 valve slugbox:
    9 l/100 km in suburban driving.
    7.5 l/100 km on freeway.
    When using low octane petrol, the car drinks it faster.
    I think that Mobil has a policy of keeping RON 95 within 5Ę of RON 92.
    Fellow Frogger! Ren25's Avatar
    Dec 2002
    Perth
    299
    My onboard computer is in overload mode. Shanes original question was in MPG and yet everyone has answered in metric. Can we please standardise 'cause I can't do the maths.
    Mike
    PS and don't come back with any complicated conversion formulas OK?
    Armageddon was yesterday
    Today we have a problem
    2000 406 Hdi X 3
    2003 307 Hdi
    Sep 2005
    Scotland
    169
    I'm going to come back with another different measurement type as litres per 100Km is alien to me too
    I only ever do around town driving and I've been struggling to hit 10Km / litre. Typically I get 8 to 10Km / litre which is more thirsty than my 2 litre manual Honda accord (manual) used to be
    So I think they are a bit on the thirsty side.
    Simon
    8,923
    Try here to convert:
    http://hemsidor.torget.se/users/b/bo...nv2_e.htm#fuel
    which should tell you that rather than
    should perhaps read
    So I think it is a bit on the thirsty side.
    by using the comparisoon of other cars.
    Alan S
    16,424
    Thanks Guys,
    do you use the cruise control. This is the first time I've ever bothered use it ... I'm thinking possibly it's whats cost me the economy. Every slight hill/gradient is cracking the throttle wide open... You can feel it constantly surging to add the 2km/h back on it's dropping. Constant accellerator adjustment will also use lots of fuel. Everytime you move the accellerator it richens the mixture.
    I'll start with the air-cleaner I think. Everything works perfectly on the car, slugomatic is fine and appears to lock into top. It run on standard ULP up there and PULP running back. As always I could pick no difference and the economy was identical.
    North Brisbane
    1,928
    Shane,
    I've found on our 16 valve, that after a tank of ULP, the engine runs like a dog for about the next 3 tankfuls of PULP until the ECU finally recognises the better petrol and advances the ignition back. The best way to sort this is to reset the ECU by disconnect the battery for 10 minutes of so.
    Perhaps you could try this with yours and see if it that works too.
    Ken W
    16,424
    Thanks Ken,
    I'll try that ... The problem is the motor runs perfectly ... Sure it's slow (it is a 1.9litre motor pulling dragging a 1500kg lump of metal around through a slugomatic gearbox)... It does run well though, and really seems to hit a power band at 4500-6500rpm.
    The fact you guys can pick the difference between fuels and I can't possibly points to it not advancing the ignition when better fuel in put in the tank ?
    Member dom19's Avatar
    Sep 2005
    Lobethal
    87
    Default Mpg
    Shane, when I drove my xantia back from Sydney last weekend I got 38 mpg, slugomatic, aircon on auto, 100-110 klm all the way. One half hour period at 5-10 klm on hume leading up to roadworks.
    Dom
    Xantia SX 1997
    Toyota Spacia 2000
    8,923
    Shane,
    The only difference I found in mine when I went to ULP was that it pinged as I hit the gas pedal just a 'craaack' and I could almost see the needle drop on the fuel gauge.
    Alan S
    Sep 2005
    Lobethal
    87
    Default More info...
    Car had just been serviced,new air filter,plugs, synthetic eng.oil(if it makes a difference???) no Cruise control car is 8 valver , filled it with PULP just me & over night bag. I think you are right about cruise controls. my experience is they are constantly kicking down the auto on hills & increasig engine speed when without it youd let the car slow then increase speed on the down hill run.
    Dom
    Xantia SX 1997
    Toyota Spacia 2000
    Fellow Frogger! Trixie's Avatar
    Aug 2005
    Sydney, Australia
    495
    Our 8 valve manual (Optimax) gets:
    Country cruising 110km.h: 35mpg plus (8l/100km)
    Spirited driving open road: 30-33mpg (8.5-9.5)
    Outer urban running: 24.5mpg (11.5)
    Inner urban with a/c 23.5mpg (12)
    Best ever is 38mpg (7.4), worst 21mpg (13.5)
    mpg x l/100km = 282
    John
    2005 Renaultsport Clio 182 Cup - French Racing Blue
    2008 BMW 325i M-sport steptronic sedan - Alpineweiss
    2010 BMW 320d Touring Innovations - Space Grey
    16,424
    Thanks Trixie,
    yours is nearly a sister car to mine, so the economy I'm getting actually sounds about right I'd consider using the cruise control definatly as "spririted driving" particually the way it constantly surging the car forward in an effort to sit on exactly the speed it's set too.
    Strange as it sounds, short of open ride driving without cruise control the old CX appears to return very similar fuel economy figures. I guess it's in the weight and gearing. The old CX is rolling along at 2200rpm @ 100km/h effortlessly, where as the Xantia has the throttle open much wider at 3000rpm. Remembering they probably weight about the same. The Xantia is most certainly NOT a light weight like the BX. With the same driving (same motor) in the BX we used to consistantly return about 44mpg.
    Aug 2005
    Sydney, Australia
    495
    Thanks Trixie,
    When you drive them, they feel very economical - the easy low-down torque and the fact you can change up under 3000rpm and still keep up. And you hardly ever see the red side of 4000. The quoted kerb weight is 1238kg (the C4 1.6 is apparently 1200kg ). Then again the gearing is low-ish and I tend to drive briskly.
    I suspect if I bothered to try I could get very good economy but....
    Reminds me of my Dad who was crowing about getting something like 46mpg from his Saab 9-3 Syd-Adelaide. I asked him if he enlisted any special techiniques and he told me his secret was to sit on 80km/h
    John
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,864
    Wow thats some pretty good figures. I reckon in the VR 3.8L 6cyl Commodore gets about 16+L/100 km (could be alot higher I reckon?) in the inner city!
    I havent had the time to work it out because I dont drive the car for a duration of a whole tank so i cant really calculate it accurately.
    Pretty good figures on the Xantia though especially its a "older" PSA motor. What other cars did the 8v motor feature in?
    Stalled
    2005 Renault Clio 182 Cup
    Mar 2005
    Sydney 2087
    189
    No cruise control, and the car does ping with ULP 92, but the exhaust sounds like there's plenty of ignition timing advance.
    The quality of petrol seems to vary depending on where you are.
    2003 C5 2.0i AL4 205,000 km 76372389
    Dec 2002
    Perth
    299
    Quote Originally Posted by Trixie
    Yeah I remember my first trip across the Nullabour in 1967 with an EH and trailer 30mpg average (I was in the back seat) 100km/h was a rare event. Sorry, I go to sleep really fast at 80km/h, a little less at 110 and don't have a problem at 130.
    Mike
    2000 406 Hdi X 3
    2003 307 Hdi
    Fellow Frogger! whitegoshawk's Avatar
    Oct 2003
    Sydney (sometimes)
    309
    My Xanita averages 10.8l/100km in the city. Lead-footed size 9 boots driver in dismal city traffic (sydney) running on 98 octane.
    Don't have good highway figures yet; will report back in a week and a bit once I have been driving it a bit on holiday!
    whitegoshawk (burn those dinosaurs! )
    "You see, wire telegraph is a kind of a very, very long cat. You pull his tail in New York and his head is meowing in Los Angeles... Radio operates exactly the same way: you send signals here, they receive them there. The only difference is that there is no cat." - Albert Einstein
    Xantia Activa CT - Chock full of upsy-downsy goodness!
    Oct 2003
    Sydney (sometimes)
    309
    Ok, got the numbers from some stylin' down the Hume... Try 7.5l/100k on 95 octane
    Not bad really, at this was also quite heavily laden with gear.
    Probably 2 passengers' worth in terms of weight.
    In imperial measure (It does make more sense that way around) my figures are;
    21.7 MPG city
    31.3 MPG Highway
    That's a 2 litre CT Turbo (petrol) engine with A/C on, BTW.
    whitegoshawk
    Dec 2004
    Scotland
    135
    Hi there
    Looking at the sort of fuel consumption various people are getting, I find most of those figures far too high.
    With my 1.9l Zx of course without A/C i expect about 100 miles per 10 litre of fuel , at a steady 60-65 miles, this means about 6 l per 100 km.
    Of course my ZX is a diesel!!!!!!!!!
    cheers Helmut
    16,424
    I've asked this question on the old Anydspares board .... and IMO not many people actually recorded there fuel economy accuratly there. ie: fill tank, reset odometer, drive distance and refil tank totalling the fuel that was put back in to fill the tank and the milage done.
    The ones that recorded the lower consumption figures did the maths/economy correctly. The CT turbo above sounds slighty better (if not the same) as the economy figures they were all getting (I'm not sure how it uses so much dino juice ). In my mind a 20year younger Xantia with a motor that is modern and can't have it's origins traced back to the 1930's should get better fuel economy than my CX turbo
    8,923
    Don't forget that your CX didn't have all the anti-pollution politically correct crapalytic converters, anti smog anti everything valves and restrictions either and even if it did, by now they'll be all off it anyway.
    With the 16V I find it very economical until I decide to give it a bit of stick and then I can almost watch the needle fall, yet by comparison, Brad's series one withoout a lot of this crap, seems to get good mileage regardless of the way it's driven. I think that tells the story.
    Alan S
