Basic question - pressure release
Results 1 to 9 of 9
    Fellow Frogger! blomquvist's Avatar
    Apr 2003
    Elsternwick
    156
    Default Basic question - pressure release
    Gentlefrogs,
    Fundamental question - where do I locate the pressure release valve on the XM? (please don't smirk too much). It's been mentioned to me a couple of times, but I can't find it.
    Waiting on Haynes manual to arrive from the UK, but getting impatient. My Nylander strut top replacement kit has arrived from Norway and I am planning the installation, before the strut harpoons my bonnet.
    Yours in conscious incompetence,
    Greg
    1992 Citroen XM 2.0i Prestige 1989 Peugeot 205 GTI S2 (Little Red Car for sale) 1998 Volvo V70R AWD (Big Red Car)
    CitroŽn Tragic UFO's Avatar
    9,721
    Ha ha ha ha ha ha
    Sorry, didn't mean to laugh SO much.
    The pressure reg on your XM is straight below the dizzy. To get to the 12mm nut you need to have the front of the car on stands or ramps, undo the 4 10mm nuts holding on the small guard under/behind the lower end of the front bumper and then look up - with your mouth closd to avoid LHM drips.
    It will all make more sense then.
    Do a search on this forum for the procedure to fully depressurise an XM including centre spheres.
    Regardless of the Nylander thing, you will still need to start sourcing new strut mounts one day - make sure that you get yours from the UK AND spec they are for your particular model, as they will be lesser internal diameter than Aus spec cars. All V6 builds (well those made for Aus anyway) had thicker struts therefore the hole in the mount is bigger.
    Unless of course you want to source new mounts and struts...
    Apr 2003
    Elsternwick
    156
    Quote Originally Posted by UFO
    Ha ha ha ha ha ha
    So much for being non-smirking (drops v. bad French accent and resumes normal voice)
    Thanks Craig. (sound of coin hitting floor) Ah - so that's why ramps are so important in the process.
    And yes, there's a new strut lurking somewhere in the future, but for now, $140 beats $750.
    16,422
    On the Xantia with the same motor as your car it's the yellow circle
    on the CX it's the white painted nut:
    or even easier ... on the sphere tester the spanner is swinging from it:
    The regulator really is quite similar on all models. ONLY RELEASE IT HALF A TURN !!!!! You should hear the pressure escape
    9,721
    DER! I forgot that Greg's car is one of the models that has "swingacatinhere" space - lucky mongrel.
    Ignore instructions about ramps etc unless of course you are doing the front centre.
    Then come back to use when you want to do rear centre
    Apr 2003
    Elsternwick
    156
    Wow. Can't much much more explicit than that Shane. Do you want some consulting work in developing instructional materials?
    Greg
    PS. I'll be in Ballarat for a few hours sometime in the next fortnight and would be good to see the CX GTI, but it's a work trip (despite involving motorcycles).
    Apr 2003
    Elsternwick
    156
    Woof.
    9,721
    Quote Originally Posted by blomquvist
    Greg
    Typical of CX design, you have to take the drivetrain out to release the pressure
    16,422
    No worries Greg,
    let me know when you'll be about. If you like we can chuck the Xantia up on ramps and pull some of it's sphere's off (it's basically the same as your XM).
