C-matic - Where do I fill it?
Results 1 to 2 of 2
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Hopefully I will be putting the c-matic back together in the next day or so.
    The question is, can I fill the oil through the dip stick hole?
    Haynes' little *funny story* book shows a drawing of a filler plug which usually means it would have been a photo if they could have seen it or they forgot to take the pic whilst the motor was out :p
    It's been a great experience; one that I have no desire to repeat
    Alan S
    16,383
    Alan,
    some spot as a 4spd isnt' it?? You'll need a plug spanner to remove it. could be worse you could have a 5spd & unless you remove the camshaft pulley you can't pull the filler plug.... grrr.
