Xsara 2002 VTS coupe - Really Heavy Clutch
Results 1 to 21 of 21
    Oct 2005
    Perth
    13
    Default Xsara 2002 VTS coupe - Really Heavy Clutch
    Hi all,
    just a quick question.
    I took a Xsara that i am interested in buying for a test drive recently, and i could not beleive how heavy/stiff the clutch was. My friend also had a drive, and said he had driven trucks with lighter clutches.
    Can anyone shed some light on whether this is the norm, because i was suprised that any company would sell a car with a clutch like this. I would be able to get used to it, but i just don't want it to be an actual fault.
    That is the only real thing standing in the way of me buying the car.
    Cheers for your help
    Tadpole O'Murchu's Avatar
    Feb 2005
    Wentworth Falls
    20
    It definitely ain't the norm!.
    The VTS clutch is very easy to work. Super-responsive, and if the truth be told, a properly adjusted one is very light. Alas, i'm no longer the owner of the best recent Cit. I sold it on Saturday just gone, after a six month wait. Now jetting around on a bike and a 1960 ID(obviously jetting is the incorrect verb in this case).
    regards,
    Keith
    1000+ Posts TroyO's Avatar
    2,511
    I suppose it depends on how you define heavy. I have found the clutch action on all 3 Xsara's I owned to be a bit on the heavy side, but you would get used to it. I think the issue might be something to do with the path the clutch cable takes in the engine bay.
    Troy.
    Fellow Frogger! Clogzz's Avatar
    Mar 2005
    Sydney 2087
    189
    Probably worn clutch plate.
    As clutches wear, they get heavier.
    Oct 2005
    Perth
    13
    Thanks for the responses.
    Doesn't sound good
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    As has been suggested, it may be that the clutch cable might be turning too many corners or it may be like my 16V that somebody removed the heatshields near the exhaust manifold and cooked the outer casing which allowed water into the cable causing it to rust and snap.
    These clutches they tell me operate on a pull not push principle and when the throw out bearing begins to wear into the fingers it gets heavy, so I'd be inclined to say it's a worn clutch.
    On the Xantias, they use a plastic clip at the pedal end, so it seems normal procedure to pop one clip, fit a new cable, then if the second one goes in a reasonable space of time, they then replace the clutch.
    If you like the car and the price is reasonable, drop it on them to do the clutch as part of the deal or go part way with the cost for your own peace of mind, otherwise the next car you find might have a nice soft clutch but be a bucket of bolts in other respects.
    Alan S
    Oct 2005
    Perth
    13
    Very true,
    decisions decisions.
    NSW
    4,917
    What is the price in getting this car repaired then this might help him with his decision to buy it or not?
    8,923
    Quote Originally Posted by danielsydney
    I've never been around one of these but I'd imagine it's no big deal.
    Say 6 hours labour and $300 parts as a top end figure I would think. No doubts someone who knows them might be a bit more accurate.
    Alan S
    NSW
    4,917
    Oz
    Hope this gives you a rough idea on what it will cost to get fixed. The xsara is a great little car (dashboard bland black) but overall a great machine.
    Oct 2005
    Perth
    13
    Yeh i like the car overall, its just the clutch issue
    Im not mechanically astute enough to know exactly what the problem is either, maybe i could take it to a local citroen mechanic and get him to check it out?
    Gordon, NSW
    4,527
    Sounds pretty normal to me. The VTS and GTi6 both can get quite heavy clutches, and they'll feel even heavier if you've come from a Japanese car. You'll quickly get used to it and once warm the clutch is perfectly fine.
    It's normally caused by a stiff cable, so lubricating the cable can help. However, get it checked out, as the clutch could be overly worn, but a bit hard to say if the only symptom is a heavy clutch...
    It's a pretty powerful engine, needs a fairly decent clutch to handle the power...well torque, more...
    - Lincoln
    2,511
    Quote Originally Posted by The Oz
    If you want to be absolutely certain then that may be a good idea.
    Troy.
    NSW
    4,917
    Any French specialist in WA should know after checking the car out if its good or not.
    Oct 2005
    Perth
    13
    I spoke to a Peugot/Citroen dealer in Perth and he said a change of clutch cable could be order and that would make a world of difference (around $350 including labour).
    A new clutch he said would be around $1000 so thats ok.
    Anyway i made an offer and will see today i hope if its accepted.
    NSW
    4,917
    Oz
    Good luck with it hope your successful. Is it a series 1 xsara or series 2?
    moosey
    Guest
    Quote Originally Posted by GTI124
    I've been told this too. How many km's has the car travelled? I drive a 306 S16 a couple of years ago with about 110K on the clock. The clutch was mega heavy.
    8,923
    Can I suggest you play some mind games with this dealer?
    See if you can get him to look at the car and diagnose it on the basis that as far as he's concerned, you'll be submitting an offer based on his diagnosis; that way he should be pretty careful what he tells you.
    It may also be that he knows the car and this in itself might give you a FSH free of charge.
    Alan S
    Oct 2005
    Perth
    13
    The dealer in Perth doesn't know the car because its actually come over from Vic. The sale is private so i don't know if mind games with the dealer will help
    It was a demo originally, and the guy selling it is the 2nd owner since.
    The car has done 62,000km's and just had it's major 60,000km service (timing belt changed). I asked the owner if he had any problems with electrics thus far and he said no.
    Im not sure if the car is series 1 or 2, how do i check on that? It was built Nov'02
    Cheers all, very helpful anyways
    edit: the car has been for sale advertised on this forum 2002 Xsara VTS - For Sale
    Fellow Frogger! mattg's Avatar
    Feb 2005
    Port Macquarie NSW
    191
    Hi and hopefully welcome to the wonderfull land of VTS ownership.
    I found my clutch a little light when I bougt mine compared to the HD clutch I'd put in my last car to handle more Booooost Mate.
    it only had 11,000 km on it so I'd be concerned about the clutch being on the way out. I looked into a new clutch before I bought it and it was aroun $500 just for the Parts kit.
    Let us know if you get it.
    MattG
    2002 Xsara VTS
    2,511
    Im not sure if the car is series 1 or 2, how do i check on that? It was built Nov'02[/url]
    It's a series 2. We never got the series 1 VTS. The front end is the giveaway. The series 2 cars have nose with the big headlights, whereas the series 1 has the slitty headlights like the following
    The colour is Juane Heliodor, the same colour as the VTS I had. They are a rare beast in Perth. Good car.
    Troy.
