2CV on the road
Results 1 to 25 of 34
Thread: 2CV on the road
    Local Tyrant gibgib's Avatar
    Mar 2000
    Sunshine Coast, Queensland
    3,515
    Default 2CV on the road
    At last I have my 2CV on the road
    Driving it today there is quite obviously some pinging going on under load, it's more a pop sound.
    As far as I know (AKA AFAIK) the fuel I put into it came from my lawn mower supply gerry can which is Ultimate 98 ron.
    If anything, I thought this fuel octane should have improved a potential problem in this department. I have checked the timing & it's dead on.
    Do I need to retard the timing or try a different brand or octane?
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    How old was the fuel?
    If it was an EFi car, it would be a bit more mystical, but as it's a basic system, I'd be inclined to go for a tankful of newer juice before I started doing any adjustments just in case you have mistakenly filled it with ULP.
    If that fails, then opt for a slight retardation of the spark. Better if you don't have to performacewise.
    FWIW, some of the guys doing the sprints circuit are of the opinion that Optimax for example has a tank life of one week. That's what I meant by "old" fuel.
    Alan S
    Mar 2000
    3,515
    Yeah the fuel was about 2 weeks old.
    Reason I ask, I want to fill 'er up tomorrow & at this stage I may try Optimax & see what happens on that.
    16,426
    Hey Gerry,
    Join the 2cv list on www.yahoogroups.com ... You'll get endless help for 2cv's there
    6,306
    Gerry, that's the sound of those tiny cylinders firing normally...
    2003 PEUGEOT 206 GTi
    Mar 2000
    3,515
    I'm on that list but I thought I'd try here first.
    Incidently, is there an easier way to search a yahoo list w/o the "search more" senario?
    Mar 2003
    Location Location
    1,576
    Gerry, is it cooling sufficiently? (esp in this brisbane heat lately).
    Not sure with aircooled engines but carbon build up can create hot spots leading to detonation. Water injection could help... or, see if it still does it on a very humid or rainy day (whenever that will be )
    5,123
    My mate who works in a country garage has many customers with problem small engines and a lot of the time the problem is stale fuel. Would aceton rejuvenate it and stop detonation?
    The other day i saw an additve at bunnings called fuel preserver or conditioner.
    May 2004
    QLD
    47
    Quote Originally Posted by gibgib
    Does it sound like its only firing on 2 cylinders?
    Chance.
    Mar 2000
    3,515
    Filled it up on Optimax & the problem seems to be gone, although I only drove about 5 k's.
    It does actually. Perhaps that is the problem. It says 2C V6 on the boot lid so I've got 4 lazy ones happening
    It was doing it even when cold so I don't think it's due to the heat.
    All reports indicate the 123 ignition fixes faults like this. I think I will invest in a blue one with the vacuum advance addition.
    Aug 2003
    Australia
    113
    Quote Originally Posted by JoBo
    Although I realise that for every person on this forum that says 'I've used "Product XYZ" and it worked' there are three others who pipe up and say it doesn't, I'll stick my neck out and say that I've been using Moreys Upper Cylinder Lubricant for years and I'm really happy with it, and it is meant to be a fuel stabiliser too. It goes in both my (air cooled twin) bikes and both the GSs without fail (in conjunction with PULP).
    Based on my own experience with my 900 Duke I'm also inclined to accept Morey's claims that it prevents fuel going off, or at least slows the process down. The bike is EXTREMELY sensitive to fuel quality and as it's not the sort of bike one rides to work, depending on the weather, etc a tankful of gas can hang around for a month or so, but I have never had a problem with it that I could attribute to stale fuel.
    Being desmodromic it has, by production car standards, quite critical valve clearance requirements however I've achieved excellent results here also. The Cits run well on it and I've had to adjust valve clearances twice in around 70,000km, rather less often than the factory recommendation for these engines, reinforcing for me, at least, that used correctly it will prevent VSR as well. Best of all it's reasonably cheap! Not sure if it's sensor safe though, would check this out before using in any vehicle with an O2 sensor. No doubt others will beg to differ with the above but one of the great things about this forum is that you do get a variety of perspectives from the members...
    Gerry, I've been wondering how you were going with the 2CV since we exchanged PMs (a while ago now) great to hear you've got it on the road. If all else fails perhaps stick in some octane booster after a tankful or too if there's been no improvement, at least that will eliminate insufficient RON as a quality issue if nothing else, and as a last resort even try refuelling at a few different outlets. How about a photo or two of the beast?
    Brett
    Mar 2000
    3,515
    Some pics.
    The second pic is the underbonnet everything melted before repairs, then 2 from yesterday morning to up my Shannons insurance agreed value.
    The interior will be plum & custard tomorrow (hopefully) to match the outside.
    More to do yet!
    Man it's cool
    Attached Thumbnails Attached Thumbnails 2CV on the road-dolly0.jpg   2CV on the road-dolly3.jpg   2CV on the road-dolly4.jpg
    NORTH PERTH W.A.
    830
    Default I Agree
    I agree totally with brett Moreys works a treat .I use it in all my cars as sometimes they sit for extended periods while I play with other toys. Fuel stays fresh and even doesn't get that stale smell Moreys and Ultima makes all the oldies go like stick pity it doesn't help them stop in a staight line
    Aug 2003
    Australia
    113
    For some reason those colours seem to suit them so well don't they? But some of that wiring looks NASTY! Was this fire damage Gerry? Great to hear it's running well now anyway.
    Brett
    Mar 2000
    3,515
    Quote Originally Posted by Brett R
    Brett
    There was a fire somewhere, it may have began at the stereo that had been installed (found + wire rubbed through on body), however I found some perished fuel line as well & have also heard the heater pipes often drop onto the exhaust causing fires
    I took it for a spin to the Sunshine Coast today. It happily sits on 110k, but I think it is most happy at 95k.
    Travelled about 240k's on half a tank, prob 12 litres
    Major failure at Beerwah though! A valve spring snapped
    Dad towed me to his place & we fitted a GS valve spring.
    Only difference we could find was varying tensions. The 2CV ones require more force to compress.
    I drove it back to Brisbane with no problems & certainately not in a hurry to replace with a 2CV spring
    Thanks to Peter F & Steeley for their phone support.
    I will be changing the oil again tomorrow, retarding the timing, re-routing the speedo cable (noisey), greasing the steering column & some other little things. Hopefully my interior can be fitted also.
    16,426
    I think the idea is just to cruise on 70mph with your foot flat to the floor. I've heard many times the worst 2cv's are the ones that are treated gently
    Don't lubricate the gearshift with any mineral oils, it swells the bush, rather use something like silicon spray
    8,923
    That valve spring wasn't what was being mistaken for the pinging by any chance?
    Alan S
    Mar 2000
    3,515
    Valve spring was broken in two bits & made for instant failure of engine. No compression on right hand cylinder.
    I am getting 135 PSI on both cylinders now, I assume is OK for 8.5:1.
    The pinging still remains under load but much less on the Optimax fuel.
    12,256
    give it the redex treatment and if that fails then let me know if you need any help sticking water injection on it
    BTW DO NOT back the car up to the better 1/2's white sheets on the line when giving the redex treatment as you may find yourself living in the 2CV for a while
    and please take pics while doing it as i'dlove to see a james bond 2CV in action
    1 x '98 306 GTi6
    Mar 2000
    3,515
    Ping almost gone. I think it will do the way it is for now until 123 ignition blue is purchased.
    Retimed the engine (after grinding back the pitted points) to best I could muster at 8deg & slightly less on the other side of points cam.
    Bought 6litres of Castrol GTX oil from Super Cheap for $11 to clean out engine before adding the new oil filter & Mobil 1.
    Re-checked the tappet clearances while the covers were off, only one needed attention.
    Degreased engine bay (not that it was bad) concentrating on the oil cooler & barrell fins behind the fan.
    Also managed to fix heater flap, it was always half on - not good in qld.
    Will do the steering column tomorrow, which looks as though I need to undo at the spline on the rack to get the grease down the tube.
    I recommend buying 2CV parts from http://www.2cvaustralia.com.au/ online shop. The owner is most helpful & anything I have needed thus far has been in stock & delivered promptly. Very happy with the service
    Tadpole TinSnail1's Avatar
    Mar 2003
    Perth, WA
    28
    FANTASTIC to see another Deux Chevaux on the road in Oz!!!!!
    1986 2CV Spťcial - Australia
    Fellow Frogger! chris's Avatar
    Jan 2005
    Sydney/Marsfield
    376
    That Bond 2CV had a GS engine in it
    GS 1220 break. Beige cars go faster
    Mar 2000
    3,515
    Ended up prysing the rubber gromment behind the steering wheel enough to allow oil can nozzle to fit & squirt some oil down the tube.
    If it happens again I will tap a thread & stick a grease plug on the column!
    Washed & polished & went for a drive to Wivenhoe Dam this arvo.
    Pictures attached of clean duck.
    Attached Thumbnails Attached Thumbnails 2CV on the road-dolly5.jpg   2CV on the road-dolly6.jpg
    Mar 2000
    3,515
    Couple more...
    Attached Thumbnails Attached Thumbnails 2CV on the road-dolly7.jpg   2CV on the road-dolly8.jpg
    1000+ Posts BogMaster's Avatar
    Canberra,act,australia
    1,457
    Couple more...
    Have you fitted the grass catcher yet GG?
    Woo Hoo Honi ko'u 'elemu (Hawaiian)
