Error code 14 on bx19 TZI
    Oct 2005
    norway
    3
    Default Error code 14 on bx19 TZI
    Hello. I get an error 14 on the ecu. Do any one know witch sensor that is defect. ???
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    "Ignition NTC sensor"
    Refer
    http://www.vectorbd.com/peugeot/files/405ecu.pdf
    Alan S
    Oct 2005
    norway
    3
    Tanks for the replay. but
    That did I also find out. But I can't find out what it means. or wher the sensor is.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,928
    The 'blink' codes are pretty similar across all Citroen/Peugeot ECUs. Here is a description from a listing of XM codes. It inculdes the resistance in ohms of a typical sensor at different temperature points.
    14 Cooling water temp sensor [email protected]; 2,[email protected]; [email protected]; [email protected]
    The BX DIY site also reports this as the coolant temp sensor and has a resistance/output vs temp graph for the sensor.
    http://www.tramontana.co.hu/citroen/fuel/test.html
    The temperature sensor is one of the sensors mounted on the back of the casting that the water pipes come out of on the end of the head and is under the distributor. Other sensors there are for temperature gauge and over temperature light.
    Hope this helps.
    Ken W
    Oct 2005
    norway
    3
    Tanks a lot. When I did know wher to look I did find the problem. Falty wire on the sensor.
