bx hyd
Results 1 to 7 of 7
Thread: bx hyd
    Jun 2004
    perth
    5
    Default bx hyd
    have problem front height corrector blows off dust cap and diapham
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Quote Originally Posted by chevronwa
    I'd ask you to be a bit more vague if I thought you could be.....but can you give a bit of detail??? It's nigh on impossible to diagnose anything from that!
    Alan S
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,928
    Sounds like a return line or one of the return passages in the height corrector is blocked so that when it tries to return LHM, it build pressure until the end cap blows off.
    Ken W
    8,923
    You've done well; now, has it recently had any work done on the hydraulics, how often does the P/R tick, is there any air in the system, does it do it all the time or when it settles, is there any noise from the pump, is there any problems with the ride????????????? and so it goes on.
    That's what I was talking about.
    Alan S
    Member docchevron1472's Avatar
    Bristol / England!
    40
    I've seen several BX's over here with similar problems. It's usually the seal failing and vast sums of LHM are emitted. Of course, if its not leaking vast amounts of fluid then it probably aint that. We've had a few that have worn a lip in the piston and leak only at a certain point of travel on the corrector.
    BX 19RD Hybrid, BX 16Valve Phase 2 , BX 19GTI Hurricane, unique BX 17TD Automatic
    16,424
    My $$$ are on the blocked return track inside the height corrector (or the line upto the tank) as well. When was the LHM last changed I suggest once you have dismantled and cleaned the height corrector (don't replace it, it'll be fine) that you flush the system and change the LHM.
    Jun 2004
    perth
    5
    problem fixed replaced hight corrector , in bin
