How to make your own hydraulic pipes
Results 1 to 22 of 22
    Bristol/England!
    1,486
    Default How to make your own hydraulic pipes
    There have been a number of threads recently about hydraulic pipes, and how expensive they are to have replaced.
    This need not be the case, if you make your own.
    Pliedes have a branch in Australia, and sell all the stuff you will need.
    A roll of cupro-nickel pipe, about 20 metres is more than enough to do a whole car.
    A flairing tool, I found the hand held one best, as you can work directly on the car with it, where you can't with a bench one.
    An assortment of screw ends, seals, and maybe 2 or 3 double ended female couplings, depending on how many pipes you are going to renew.
    First, using a junior hacksaw, cut a piece of pipe to just over the length you need, and then gently file the end to get rid of sharp edges or burrs.
    Next, put a screw end on the pipe with the thread closest to the end of the pipe.
    Carefully line up the end of the pipe with the line in the lower half of the flare tool, and making sure the pipe doesn't move, screw the top half of the tool on very tightly.
    You can hold the tool in a vice, or with a 1 inch open end spanner. Insert the big flare screw, and turn with a spanner all the way in, till it bottoms out, then unscrew it completely.
    Undo the top half of the tool, and your flare is made, just put a seal on the end, bend to the right shape and the pipe is ready for use.
    The pics show me working with the most common 3.5mm size of pipe, but it's exactly the same for 4.5, or 6.5mm. (different size tools and screw ends/ seals, would be needed)
    john s
    Attached Thumbnails Attached Thumbnails How to make your own hydraulic pipes-pipe1.jpg   How to make your own hydraulic pipes-pipe2.jpg   How to make your own hydraulic pipes-pipe3.jpg   How to make your own hydraulic pipes-pipe4.jpg
    NORTH PERTH W.A.
    830
    Default The Tool
    can anyone tell me whether this tool is available in australia and from where ? thanks
    16,414
    I've got one here, but you would still need to order the line in !!
    NORTH PERTH W.A.
    830
    Default Thanks Shane
    Shane your there and i'm here on the other side of the world . Did you get the apparatus locally? I mean in australia or did you have to import . I am a toolaholic so wouldn't mind one in my kit for future and present endevours . I assume all citroens ie hydraulic ones run the same pipes and fittings ?
    16,414
    Quote Originally Posted by ARCHRIVAL
    I only have a 3.5mm line flarer. I got it with a trailer load of parts I bought. It's very small and I could chuck if in a postpack envelope to perth if you want to borrow it for a few weeks.
    There is Plaides in QLD, I'm sure they will sell you the tool. Didn't Smiffy say all the line and flaring tool was 80quid all up, so not bad at all (probably add another 20quid for postage).
    NORTH PERTH W.A.
    830
    Icon14
    thanks Shane I have sent an email to
    Pleiades Automotive Hydraulics (Australia)
    PO Box: 40
    Gayndah QLD 4625
    Phone: 07 4161 2512
    Fax: 07 4161 2512
    Email: [email protected]
    to see what they have got if they have all the stuff i might make up a kit
    Jul 2004
    CLARE SA
    2,324
    Any competent plumbing hardware store should have or be able to source these.
    ed ge
    16,414
    Quote Originally Posted by edgedweller
    ed ge
    It's not a standard flare, it's a bubble about 5mm from the end of the line. There is bubble flares on cars now in the US (I've seen there bubble flare tools on ebay), however the line sizes are quite different .... Most likely NOT metric
    We need, 3.5, 4.5, and 6.5mm flaring tools.
    Fellow Frogger! sdabel's Avatar
    Jun 2003
    216
    Icon10
    Shane, Just waiting for you to set up citroen hydraulic lines dot com!
    regards
    sean
    _____________________
    1996 XM 2.1 TD Exclusive
    CitroŽn Tragic UFO's Avatar
    9,719
    I think you'll find that the larger pipe is 6.45mm, which just coincidentally is 1/4 inch. This is why when you get a rubber to metal pipe made (eg relocating DS pressure reg) you talk to them about 1/4 inch pipe at each end. Brains usually melt when you mention 6.45mm. I suppose 4.5 would equate to 1/6th (?) and 3.5 to 1/8th?
    My
    Bristol/England!
    1,486
    TOP TIP HERE!!
    If you are replacing a hydraulic line, and it looks corroded and yukky, ie, if you show it a spanner it will round off, Don't even try it!!!
    What I did on my car, is cut the pipe with a hacksaw right near the screw end, and using a deep SINGLE hexagon socket, not double, I was able to unscrew it without it rounding off.
    The new fittings that you get from pliedes are no longer the 8/9 mm fittings, but are machined from a 10 mm hexagon extrusion, that is then coated with Zinc, so it will last much better than standard citroen items.
    john s
    NORTH PERTH W.A.
    830
    Icon8 Kits not available in Australia
    The flare kits etc are not available in australia only from UK
    Pleiades in England can supply the cupro nickel pipe, pipe end fittings, line
    connectors seals and flaring tools for Citroen D, CX, BX etc.
    For full details please contact pleiades on: [email protected]
    Or by fax: 00 15 44 1487 832444 (phone: + 00 11 44 1487 831239)
    16,414
    Did they give you a price ... It would be interesting to know how much some rolls of cupro nickel pipe and fitting are. There are some rounded fittings (or fitting that I'll have to destroy) on the rear of my CX in order to remove
    NORTH PERTH W.A.
    830
    Default not yet
    This was the response from the australian guys and the uk crowd have not responded yet
    will keep you posted
    NORTH PERTH W.A.
    830
    Icon5 Reply From Uk
    Type A (hand held) flaring tool costs £54. 3.5mm pipe is £1.40 per metre. Male fittings are 35p each. Rubber pipe seals are 15p each. Carriage is calculated on weight so I would need to know waht you require before quoting. All are stock items.
    WHAT DO YOU THINK I WOULD NEED FOR THE CX AND AS A BACK UP FOR BX AND FUTURE ENDEVOURS ?
    16,414
    Have you thought about getting one of these:
    flaring tools
    It'll probably double the price of the flaring tool, however this will be with the fittings for all sizes of Citroen lines AND standard braking double flares for your other cars
    Smiffy would be the best to suggest lengths... However if you get one of the tools above I'd be tempted to get a few meters of 4.5 and 6.45mm line... you may never need it, but it'll be a life saver for the rust of us in Oz, 'cos we'll just email you with our piping needs
    seeya
    shane L.
    NORTH PERTH W.A.
    830
    Default Its a nice tool
    But at over $800 plus $200 for clampsets plus pipe and fittings plus postage and duty total ~$1600 I'd need to go into the business of making pipes and what is the demand in australia?
    16,414
    It's bloody expensive, but not that bad:
    80quid ... flarer with standard clampsets for all your other vehicles...
    19quid ... 3.5mm clampset
    23quid ... 4.5mm clampset
    26quid ... 6.4mm clampset
    Total: 148quid ... or $343aud
    Plus lines, fittings, seal and postage...
    Yeah .... BLOODY EXPENSIVE .... If I win tattslotto .....
    PS: You would only need two replace to lines on your car and it will have paid for itself.... Remembering 2nd hand Xantia lines out here are $200bux ++ each
    NORTH PERTH W.A.
    830
    Default umm
    shane don'nt those citroen clamps only fit the AFT the pricey one at 234 pounds ?
    16,414
    If you look in the picture it shows the exact clampsets beside it that you mention I've sure a few years back I saw this flaring tool in a UK classic car magazine, that's why it won the awards... It does all the flares of all types.
    Still it's expensive.... Then again, price a quality standard flaring tool out here and I think you will in for a shock
    Bristol/England!
    1,486
    I'm only talking about the 3.5mm lines here. If you were to buy 50 of each item (screw ends, and seals) and perhaps 30metres of pipe, that should be enough to re-pipe the CX and the BX, and leave you lots of spare!
    I only bought 20 metres, and I recon I still have more than 5 metres left!
    I recommend when you order, that you buy 3 or 4 double ended female couplings.
    You might never use them, but, If you have a problem out on the road, with a burst line, and you can't replace the whole thing there and then, you can cut the hole away, and join the 2 broken ends together, to get you home!
    I call it a get out of jail free card!
    You could then after you have re-piped your cars, make it known to other members, that you are able to make pipes to order, to help offset the cost of the tool! After hearing that someone paid heaps of cash for a second hand line, I think you could earn some money! john s
    16,414
    Quote Originally Posted by smiffy1071
    He will only need enough for any lines that may need replacing on the CX (usually because you destroy them attempting to undo them). The cars out here simply don't rott there hydraulic lines .... ever ... My '63 ID19 still has all it's original hydraulic lines. Some of them are very coroded looking though. The tools is the sort of thing each car club needs. They would then lend it out for free, but only on leaving a $500deposit to make sure the bloody thing comes back ASAP.
    Most of our cars only need line replacements where the line has rubbed though/against something.
