AL4 oil change
Results 1 to 20 of 20
Thread: AL4 oil change
    Nov 2003
    318
    Default AL4 oil change
    Just had the C5 in for it's 80k service, and had the AL4 oil replaced at the same time. Makes a big difference, much smoother changes & seems to act more decisively. The oil that came out was noticeably darker, but not black or dirty.
    My advice is: don't believe the "sealed for life" story - change the oil regularly. At $110 a pop, perhaps every 10k is a bit too often though.
    Barry.
    1000+ Posts Uga Boga's Avatar
    May 2004
    1,057
    Yep, i've noticed all the dealers say it's "sealed for life".
    But i guess if it makes a considerable improvement, it's worth the change.
    Has your C5 been trouble free for those 80,000kms?
    407 3.0L Exclusive (2007)
    Expert 2.0L (2009)
    Laguna 2.0L dCi (2007)
    NSW
    4,917
    Barry
    Isnt the AL4 in the C3 also?
    May 2004
    1,057
    Quote Originally Posted by danielsydney
    Barry
    Yes, it's in the C5 2.0L, Xsara, C4 and C3.
    Expert 2.0L (2009)
    Sense Pug307's Avatar
    Australia
    4,355
    Quote Originally Posted by Uga Boga
    More importantly, it's also in the great Peugeot 206, 306, 307, 406, 407, 607, 807, etc
    Peugeot 307 XS 1.6
    Rendezvous Adelaide 2005
    May 2004
    1,057
    Quote Originally Posted by Pug307
    No wonder it's a POS of gearbox, this must've been one of the Poogoe creations.
    The ZF, which is much more smoother, was developed by Citroen!
    Expert 2.0L (2009)
    Australia
    4,355
    No wonder Peugeot couldn't wait to get rid of it, replacing it with a superior Japanese Aisin-Warner unit
    Peugeot 307 XS 1.6
    NSW
    4,917
    Well it must be reliable if the gearbox is in Peugeot models.
    That is one stress off my mind and my wallet.
    Dec 2004
    Geelong,VIC
    81
    Uga, I wouldn't be worried about your 2003 Xsara's AL4. My 6/2001 Xsara was the first batch imported into Oz. I bought it early 2003 from Ateco's lawyer with just 8k on the clock. The first AL4 release has issues with the electro valves from the beginning. Cit and Pug dealers are aware of this.
    My problems started in mid 2004 when I noticed a lag in the tranny. Then by late 2004, the tranny skipped and went into limp mode - only runs in 3 gears, sluggishly. This happened once and cured itself. By winter 2005, this skip happened almost everyday. Since there was no Cit. dealer in Geelong, I brought my Xsara to the Pug dealer. They attached it their Proxia tester and it was identified that electrovalves are faulty. They couldn't overhaul my tranny since they were not sure if the 307 software will work on a Xsara. An upgrade is necessary after the overhaul as they will reset the ECU. They told me to bring it Melb.-there, it was again identified by the computer that electrovalves needs replacement. Cit. dealer have now installed a modified electrovalves and added magnets in the tranny to trap metal particles. The Cit. and Pug dealer explained that this was not unusual for the first AL4s. I assume that this was for models from 2001-2002. Is your tranny playing up? Have you had any symptoms I've mentioned? If not, maybe your tranny already has the modified electrovalves and magnets.
    Aug 2003
    371
    Quote Originally Posted by Juan M.
    Uga, I wouldn't be worried about your 2003 Xsara's AL4. My 6/2001 Xsara was the first batch imported into Oz. I bought it early 2003 from Ateco's lawyer with just 8k on the clock. The first AL4 release has issues with the electro valves from the beginning. Cit and Pug dealers are aware of this. ----------
    Sealed for Life - yeah right - its only true in the sense that if you dont touch it you will have very short transmission life!
    Could I be so rude as to enquire how much these repairs were worth (or how much was paid) for it to be done ???
    Fellow Frogger! vanderaj's Avatar
    Feb 2003
    457
    Although I have about 20,000 km left on the clock (so the dealer gets to do it until then), does anyone know how / where you change this ATF in the C3?
    My auto box is clunky at cold start up, shifting down far too quickly making the car unsafe if I need to apply max thrust until it gets a few km on it. I was wondering if a simple thing like ATF might help its poor manners.
    Andrew
    2003 C3 Exclusive Panoramique auto
    NSW
    4,917
    Andrew mine also does this when it is cold and just starting out. I also have issues getting to inclines on hills. I find it doesnt change back to 1st or it gets stuck in 1 gear then it changes down hard. I just put it down to the gearbox and its behavior. Under warranty it did have an electrovalve replaced but its still does it.
    Feb 2003
    457
    damn. I was sort of hoping it was something which is fixable. I'll get them to check on the firmware and for the AL4 when I get them to look at the climate aircon "clunks" which are driving me nuts.
    Andrew
    NSW
    4,917
    Mine also always makes loud clunks too with the aircon. I put it also down to something that the car just does. When my aircon was regassed, (after a dealer fiddled with it) Colliers advised it was just a noisy system but nothing seemed wrong with it.Your car is not the only one that seems to make all these noises.
    Feb 2003
    457
    It wouldn't be so bad, but with only 57 kW, the clunks accompany serious performance issues when the engine is cold. Which is why I want them to have a look... at least.
    Andrew
    May 2004
    1,057
    Yeah i get those clunks in the C4 as well, but not so much in the Xsara.
    I put it down to being part of that great French character!
    Expert 2.0L (2009)
    1000+ Posts TroyO's Avatar
    2,511
    "The ZF" is German. ZF is a company that develops transmissions and other driveline bits.
    http://www.zf.com/defaultz.asp
    Troy.
    NSW
    4,917
    Yeah 57 Kw is a serious performance factor. The clio has a bit more and I was considering the 1.4 auto in that car but I thought the look of it was not that good. Another turnoff was the wipers on the other side of the car and the gearbox was "obscure" and felt dull. Thats why I went for the C3. My car had 27Km on the clock I took it for a drive at that time and went back to the dealer and decidied I wanted it. I was also going to sell my Renault 19 and buy a Citroen BX. No dealer would trade my R19 in on one as they said they would be robbing me because my car was in better condition than any BX I saw.
    Im very happy with the C3 though even with all its "chickenpox plastic" interior and slug performance. I am in the frame of mind that I wont change for a long time.
    May 2004
    1,057
    Chickenpox interior, good one
    Expert 2.0L (2009)
    Dec 2004
    Geelong,VIC
    81
    Quote Originally Posted by 604 tragic
    604,on an earlier thread I made ($3,150 for 60K service) I posted the invoice. AL4 repair/upgrade costs around $850. This is the same price quoted to me by the Pug dealer.
