Wild Kangaroo jumpin' BX needs taming
    Sep 2005
    MADRID
    4
    Default Wild Kangaroo jumpin' BX needs taming
    Hi,
    Anyone out there have suggestions on stuttering Citroen BX engines? After driving up a steep slope the motor in my petrol BX 1.8 Saloon ( 1991 ) suffers from wild kangaroo-type jumping, suggesting a petrol feed problem. I had a re-conditioned engine fitted to to the car after the original engine seized as a result of this same fault. Despite the replacement engine ( which included a new carburetor but not the petrol pump ) the fault has continued. The fault comes and goes arbitrarily, making it hard to diagnose via a garage.
    Thanks,
    William ( MADRID SPAIN)
    Sep 2005
    MADRID
    4
    Default test
    test reply
    Quote Originally Posted by William Gibbs
    Hi,
    Thanks,
    twm
    twm is offline
    Fellow Frogger! twm's Avatar
    Hills/Sydney/NSW
    209
    Hi,
    Thanks,
    Not just an engine mount or some other mounting giving way under load?
    Terry
    Kurrajong
    Pug 206 CC 2litre
    Sep 2005
    MADRID
    4
    Default Jumpin BX
    No, i think it definately petrol/ carb or possibly ignition, though the uphill thing suggests the former. Hey, thanks for the suggestion,Á
    All the best,
    WILLIAM
    Quote Originally Posted by twm
    twm
    twm is offline
    Hills/Sydney/NSW
    209
    All the best,
    WILLIAM
    DO a test at high reves say 3500 stay in a low gear, does this make a difference.
    Only other thing I can think of is float level in the carb
    Terry
    Kurrajong
    Pug 206 CC 2litre
    Sep 2005
    MADRID
    4
    Default Jumping BX
    Yes I've tride running it at vert high revs but it doesn't seem to clear it. I'll look into the float level in the carb, that would explain why the steep hill triggers off the stuttering.
    Thanks a lot,
    WILL
