Yet another broken window mechanism!
Results 1 to 21 of 21
    Fellow Frogger! DJ-Studd's Avatar
    Apr 2003
    Victoria, Australia
    548
    Default Yet another broken window mechanism!
    Dad's C5 went back to the dealer today as the window mechanism broke (fortunately under warranty).
    This is an absolute joke, that's two Xsara's that have each had their mechanism break and now the C5!
    Cost us $600 each time the car wasn't under warranty. An absolute joke.
    </rant>
    -- DJ
    May 2004
    QLD
    47
    Quote Originally Posted by DJ-Studd
    </rant>
    -- DJ
    Which window on the C5?
    Chance
    Apr 2003
    Victoria, Australia
    548
    Quote Originally Posted by Chance
    Chance
    The rear passenger side.
    Fortunately the C5 is being fixed under warranty, but not so much luck for the 2 Xsara's that have had the same, seemingly common, problem.
    -- DJ
    Fellow Frogger! Trixie's Avatar
    Aug 2005
    Sydney, Australia
    495
    If that's the only thing that goes wrong, thats OK....
    John
    2005 Renaultsport Clio 182 Cup - French Racing Blue
    2008 BMW 325i M-sport steptronic sedan - Alpineweiss
    2010 BMW 320d Touring Innovations - Space Grey
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    When you say "winder" which part breaks? I presume it's a power window.
    I'm trying to get me head around what I know most Cits have inside a door to raise and lower a window being worth $600...
    Alan S
    Apr 2003
    Victoria, Australia
    548
    Yup, the power window. It's the entire motor mechanism, has to be replaced as one part (expensive. hmm.). Works out at about $600 with the fitting.
    The last time it happened on the Xsara, the cable basically got chewed up in the motor.
    -- DJ
    May 2004
    QLD
    47
    -- DJ
    Snap!
    Mine left the glass "floating" in the door channel. Glass could be pushed down by hand.
    Citroen dealer "fixed it" .
    Two weeks later there was a loud metal to metal bang[when closing the windows from the half inch gap position] as it failed again.
    This time they replaced parts under warranty and it has been OK ever since.
    Problem is Citroen dealer drives your car from their sales centre to the repair shop and you don't get to talk to the mechanics.
    Chance.
    Sep 2003
    116
    -- DJ
    I think I paid around $380-$410 from Citromet and fitted it myself......still a bit too expensive.
    Same thing happened to mine, the wire was mangled in the motor
    WRC CHAMPS 04!!
    May 2004
    QLD
    47
    Quote Originally Posted by Xsara VTR
    Please elaborate - I assume that there are wires from a plug to the motor.
    Couldn't the wire be cut and spliced?
    Chance
    Sep 2003
    116
    Chance
    I tried doings that, no chance.
    When I put the new one in, all the wires were tight and at the right length....so I doubt the wires can be fixed....
    WRC CHAMPS 04!!
    Fellow Frogger! chris's Avatar
    Jan 2005
    Sydney/Marsfield
    376
    Er, so cut the old wire, insert a length of new wire and solder at both ends... hell, I'll do if for you. Only $599
    GS 1220 break. Beige cars go faster
    8,923
    Quote Originally Posted by chris
    ...............cover in heatshrink and be sure to saddle and tie the wires out of the way.
    P.S. I'll do it for $598 and I'll pay my own air fares down and back.....Anyone want to better that offer? But you supply the grog!!
    Alan S
    Sep 2003
    116
    have you seen the regulator setup?? if so fair enough but then length of the wires determine the heights of the two clips holding the glass, how much they go up and down, also if you can find the clip that joins onto the wire and clips onto the glass holder, let me know..
    the wheel on my motor was also pretty damaged and couldnt hold the wires in place
    WRC CHAMPS 04!!
    1000+ Posts Uga Boga's Avatar
    May 2004
    1,057
    It's happened to mine (the Xsara) as well, but the dealer repaired it under warranty.
    407 3.0L Exclusive (2007)
    Expert 2.0L (2009)
    Laguna 2.0L dCi (2007)
    CitroŽn Tragic UFO's Avatar
    9,814
    Ah, I think the things that are breaking are the wire cables that run from the motor and activate the up and down motion of the glass. NOT the electrical supply cables.
    IIRC, a similar problem happens on S1 XMs as the nylon pulley wheel breaks or perishes.
    Aug 2005
    Sydney, Australia
    495
    Yeah, happened on our Xantia's drivers window after about 80K/8 years. $700
    John
    Sep 2003
    North Parramatta
    4,028
    Quote Originally Posted by UFO
    Oh and aren't they fun to play with
    Yes, I concur that I think we are talking about the drive cables (which of course are made of wire) not electrical wires.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    16,756
    bloody hell.... for 6-800bux ... I'd put a bloody block of wood under the window and leave it in the permanantly closed position ... That's bloody rediculous, if my Xantia does that I'll burn the bloody thing before I pay out those sort of $$$$$.
    Aug 2005
    Sydney, Australia
    495
    To be fair, as it stuffed up in the closed position, the garage did suggest doing nothing was a valid option, but my wife's work carpark has an access card and winding down the manual rear window and reaching around was driving her mad. The things we do for love.....
    John
    9,814
    Quote Originally Posted by Trixie
    Of course you could give your wife the Subaru to drive and take the Xantia yourself...
    Aug 2005
    Sydney, Australia
    495
    Apparently it 'only a Subaru'.
    (D+XM - nice choice of wheels BTW Craig.)
    John
