CX electric mirror switch
Results 1 to 9 of 9
    NORTH PERTH W.A.
    853
    Icon11 CX electric mirror switch
    The saga of the mirror switch for the new Cxt2 existing switch doesnt work at all - remove inspect power arriving no output - remove switch from BX16v install mmmmm works to well both mirrors at once on either left or right settings swap terminals either works on both or doesnt work - okay disassemble CX switch goodness gracious me no internals all gone nothing no springs no contacts who had been yanking Bobs chain
    Question anyone got a stuffed switch from a CX late 86-88 BX with electric mirrors or early XM I might be able to rebiuld this switch as the plastic is all good see attached photo????? Horn switch is interesting also I am amazed everything so easy to pull apart very different to the BX
    Attached Thumbnails Attached Thumbnails CX electric mirror switch-dcp02066small.jpg   CX electric mirror switch-dcp02065-small.jpg
    16,744
    Same thing happened to my car the day I picked it up... I touched the switch and it dropped out of it's housing shooting bits everywhere (prior to that it had only worked on the drivers side mirror).
    You probably find one of Bobs mechanics pressed to hard on it and it's guts fell out. The likelyhood of find the tiny (like minute) dog bone look alike contacts is so remote I wouldn't even bother. You can tell a true CX turbo mirror switch (as apposed to BX16valve) as the CX switch has a backlight.
    Keep your eyes on ebay, failing that I'll scratch up Stan Platts number in the UK, he should be able to post you one.
    Bristol/England!
    1,486
    Thanks for the lead on Stan Platt Shane, I need to get one, as I believe the mirror switch from my car was last seen in the Ballerat area! john s
    16,744
    Quote Originally Posted by smiffy1071
    You sent me your only switch I thought you had a spare .... or three
    Maybe you'll have to get another car for it's mirror switch (they seemed to be given away over there ).
    Bristol/England!
    1,486
    yup, that is exactly what I did, as my car was not on the road, the scrap turbo car didn't have one, and you needed one at the time. Is that what you call altruism or what? If my friend was not ill, he would have broken 3 more BX GTi cars by now, and I would have had annother switch. john s
    NORTH PERTH W.A.
    853
    Default Bx16v Switch
    INTERESTING the bx switch that I have now put in the cx has backlight and the one out of the cx that bob paid good money for a new one has no guts but the fact that both mirrors work on either left or right hand setting ? I don't want to disassemble the one switch that I have for all the reasons above. A bird in the hand is worth more than a whole lot of springs and contacts scattered all over the workshop
    Member ozziediver's Avatar
    Aug 2003
    44
    The BX switches do have backlights but most of them have blown bulbs...and as you've already found out, taking those things apart is a pain...I've had the innards flying all over the place and spent hours looking for the dogbone pieces. But managed to solder in a new bulb in one of my switches and got it working again I have a spare for parts - used it to practice on so when I tried to fix one of the 'working' ones, at least I'd know what they did...theory was good but practical went for shite! Ended up same as yours - moved both mirrors at once
    Roscoe
    1991 BX TZD
    1990 BX 16V (x 2)
    2004 307 Touring
    1990 Mitsubishi Express Van: Alpaca Transport:
    NORTH PERTH W.A.
    853
    Default Got A Switch
    Managed to find a switch fron renwreck in melbourne they have dismantled several BX16v's thanks to David from French Con' for the lead
    Bristol/England!
    1,486
    Quote Originally Posted by citti2004 View Post
    Does the control mirror switch have an internal light which illuminates the word "mirror" when the dash is illuminated?Thanks in advance.
    Mmmm, not really. The mirror switch is a for/aft and left/right switch, with a left and right rocker switch, which lives in the drivers door pocket next to the window up/down switches...and has a dim orange back light. It's on the right in UK and Australien cars, and on the left in French, and of course American CXA models.
