xsara 2001 hdi wont start
    Aug 2005
    israel
    5
    Default xsara 2001 hdi wont start
    Hi Guys,
    I need some help with Xsara 2.0 HDI 2001.
    The engine wont start at all.
    I checked all the sensors and fuel delivery and it all looks perfect.
    I also connected a scanner.
    It got a bunch of DTC's on it but I can not erase them
    What do you think is the problem?
    Do you know how to erase the faults from the ECU?
    TNX
    NSW
    4,918
    Is the battery fully charged in this car?
    1000+ Posts Uga Boga's Avatar
    May 2004
    1,057
    On that note, is there any diesel in the tank? I mean, is it empty?
    407 3.0L Exclusive (2007)
    Expert 2.0L (2009)
    Laguna 2.0L dCi (2007)
    Scotland, UK
    7
    Common problem on early HDi's over here (UK) is the low pressure fuel pump. Just packs up without any warning, usually at about 60k miles / 100k kms, resulting in a no start situation, and no sensible fault codes in the ECU. Yours is probabably about the right age / mileage. Not heard much about the later ones so they look to have sorted it. Trouble is, the pump is expensive, even here.... Don't know if there is an easy way to test it either.
    Aug 2005
    israel
    5
    FUEL -OK
    Battery - OK
    I will check the fuel pressure and pump
    TNX for the help,
    Do you know how to erase the fault codes on the ECU?
