C3 Key
Results 1 to 15 of 15
Thread: C3 Key
    Apr 2005
    Brisbane/Australia
    66
    Default C3 Key
    I am ordering another key for my Pluriel. I am told it has to be imported from France and will take approximately three weeks. Furthermore, after paying just under $300 for it, I then have to front with the car and all the other keys to a service centre (along with the security card) and pay to have them all programmed to the car.
    I understand the programming bit, but most cars can have their keys programmed by following a certain keystroke sequence. A Falcon, for example, the ignition is switched on and off a few times then the doors locked & unlocked. After this, each keypad button is pressed and the car remembers the code.
    Two questions:
    1. Does anybody know if the C3 keys are user-programmable... and how?
    2. What experiences have others had with getting keys cut? Do they really need to come from France?
    NSW
    4,918
    I can imagine the keys would have to come from France. Knowing Citroen it would also cost $300.
    I enquired about a moduboard and was told in excess of $300.
    I also enquired long back about the Citroen Picasso foldaway Shopping basket for my car and was told it might have to come from NZ and would be in excess of $400.
    Anything is possible....
    Fellow Frogger! sdabel's Avatar
    Jun 2003
    216
    Do you know anyone in the UK? When I was after bits for my XM I just called a UK dealer near a friends place and paid over the phone via credit card. A friend collected the part and mailed it over for me. A key is not going to be expensive to post. A good tip is to use Citroen .pr net, that will give you the recomended price in GBP.
    regards
    sean
    _____________________
    1996 XM 2.1 TD Exclusive
    Fellow Frogger! doggiedog's Avatar
    Sep 2004
    gippsland
    126
    I ordered a new key for the Peugeot 206cc, and it had to come from France, and the it was about $140 from memory. All keys and the car had to go in to have them all reprogrammed.
    To replace the battery in the key though, the mechanic said I could do it myself, and to reset key to the car code, you just put the key in the ignition, turn the ignition on and press one of the buttons on the key (not sure which one).
    It would be very similar for the Cit as well, I would hazard a guess.
    Apr 2003
    22
    Quote Originally Posted by JamesII
    Two questions:
    Many late Citroen keys are four sided. Local locksmiths aren't geared up to cut the 4 sided keys. That is why you order ex France using the chassis number. They send them with the sides pre-cut I believe. The non-remote keys are cheaper.
    CitroŽn Tragic UFO's Avatar
    9,809
    Keys for XMs can be cut from a blank and do not have a built in decoder. Blanks for XMs and I suppose Xsaras and Xantias can be purchased for less than $30 from your nearest Cit dealer. A reputable and experienced locksmith can cut the blank from your orginal key for you.
    The keys for later models such as C"insert digit" would be tied to the decoder and therefore have inbuilt circuitry. The dealer or servicing agent with access to the appropriate computer has to program the car's computer to recognise the key.
    It may be worthwhile trying around for prices for extra keys and programming etc.
    Sep 2003
    116
    I got a new key for the xsara for $280, $200 for the key and $80 for programming it
    WRC CHAMPS 04!!
    9,809
    So that means a Xsara must have a decoder built into the key.
    Sep 2003
    116
    Quote Originally Posted by UFO
    whats the decoder for?
    WRC CHAMPS 04!!
    1000+ Posts TroyO's Avatar
    2,514
    Quote Originally Posted by Xsara VTR
    It's part of the immobiliser system in the car. Unless all the keys are programmed to match the car, they cannot start the car.
    Troy.
    Perth Western Australia
    2,705
    Default C3 key.
    Mmmm.
    Must take the Citroen off my hypothetical shopping list.
    $300 for a key, plus a 2week wait plus a session with the dealer to have it programmed.*
    What's the automotive world coming to? What price security? Put all this along with air bags and soft front pedestrian friendly cars. God, I hope my old 504 sees me out.
    *Psst. I bet the salesm,oops, person didn't point out any of the above nonsense when he took your cheque?
    Fellow Frogger! Clogzz's Avatar
    Mar 2005
    Sydney 2087
    189
    Quote Originally Posted by Wildebeest
    Check that it's not the same stunt with all the others.
    2,514
    Quote Originally Posted by frogslegs
    I had the service key replaced on my Mk1 Xsara (back when Citroen used to give you a grey service key along with the remote and non remote spare), and I got it replaced under warranty. The key was cut locally and reprogrammed by the dealer, and it's a 4 sided key.
    Troy.
    Apr 2005
    Brisbane/Australia
    66
    A follow-up to this...
    I just had a call from the dealer. My key is ready. It has only been a week! I've yet to collect it and see if there are any hiccups, but as far as timing goes, I am impressed.
    Mar 2005
    922
    Default immobilisers
    Use of immobilisers IS widespread...in my family the Commodore has a piece of electrickery in the key that the computer must recognise..as does the Ford Laser...and the Nissan Pulsar and my son's Mazda 3
    I suspect anything that displays a flashing LED to potentiol thieves has such a system...the replacement for the Laser was $ 85 and a quick visit to a specialist locksmith that took only minutes..
    The biggest broblem is with the Commodore key that requires replacement when the internal battery dies...about $ 85 at your local GM dealer..
    So Citroen are not alone..except maybe in the over the top pricing.
