Fuel problem on Berlingo
Results 1 to 2 of 2
    Apr 2005
    Carlingford
    8
    Default Fuel problem on Berlingo
    Hi Guys,
    I have '99 berlingo and have problem with fuel. I had recall on fuel neck but still every time I fill up it keeps cutting off every 0.3L, so it takes me forever to fill up. Can enyone tell if it is simple to fix or bigger problem.
    Igor
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    To me that sounds like a breather problem that should have been addressed under warranty. Possibly it's been taken in for a mod and either not done or not done correctly. I'd suggest you contact the distributors and ask about the safety aspect of this problem as I can remember someone once posting that it can be a fire hazard, and this may be worth asking about at the same time.
    If they deny it being a fire hazard, then ask for that in writing; that should just about see it organised for you I would think.
    Alan S
