CX thermostat housing
Results 1 to 16 of 16
    77
    Default CX thermostat housing
    i have been tinkering around with my recently purchased CX c-matics cooling system ie flushing it out in my garage making an awful mess etc. I was convinced that the source of the rusty discolouration of the coolant was from a rusted out transmission fluid cooler. So on Sunday morning I decided to replace it with one in good condition from a car that I wrecked. The job took longer than I thought such that we arrived at the French car day in Sydney at 3.45! But there were still some friendly folk there to chat to.
    Anyway still not happy with the colour of the coolant today I took the car to a radiator place and asked him to flush it out for me. As he insisted upon cash as payment I insisted upon another few goes until what was coming out was clearer. He expressed his dislike of Citroens, Volvos & Mercs but I stood my ground and said I aint selling the car and it has to run properly. He thought that it had too many hoses!
    Whilst I know that the thermostat is opening and that the fans are coming on tonight I decided that I would take the thermostat out and test it in the kitchen -
    but damn it the first bolt that I tried to remove snapped.
    I am going to leave it alone but lube up the other 2 before attempting to to take off the housing. So often a little tinker leads to another problem - at least with me! but I know it has to be done so that I am sure that the cooling system is working properly.
    I did notice though that the heater was definetly working better after todays flushing.
    This car has been in storage and possibly explains the build up.
    16,756
    Not unusual at all. Infact I'm surprised you didn't sheer all of them
    I pulled the water pump off of mine to extract the bolts. However if you heat the area with a little butane torch to expand the alloy you will probaby find the stud will unscrew with some vice grips.
    Apr 2005
    Cootamundra Australia
    209
    Yep Shane, even without the heat they often come out. My Q is do you replace the bolts with the same, do you use coppercoat or do you use a higher corrosion resistant bolt?
    Cooch
    16,756
    Copper, alloy and metal don't like each other, so I wouldn't use copper grease... There's an alloy paste you can use I've heard. Me ?? I just put some more bolts back in.
    Bristol/England!
    1,486
    On nuts and bolts that are known to corrode, or snap when you try to remove them, it might be an idea to use stainless steel bolts instead.
    I'm sure they can't be that expensive? john s
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    I have a 30 year old 70HP outboard that I can still get most of the bolts that I've ever had out (ie) leg, water pump, thermostat etc because when I remove them, I always soak firstly in WD (Turps or kero = same thing) then use some penetrene followed by ordinary oil usually start one weekend and remove the next, and upon reassembly, coat with grease including head and any part of the thread either male or female that is still exposed. If you are or know anyone whose a dab hand with a welder, get the broken bit just stuck back on with a MIG and wind the thread out when it's almost cool.
    The rusty coolant is probably coming from inside the heater and I doubt you're out of the woods with it yet.
    Remove the three way plastic fitting that diverts water to the matrix and the other hose that has a connection close by the 3 way. (We call the 3 way connector "the carrot" and if you want to know why, just use any pressure whatsoever when removing; brittle as all hell) I have back flushed these several ways; one is by having the hose in one end and blowing compressed air up the other, another is to alternate the hose or air from one direction, then the other until it loosens. Water should flow almost impeded through these connections and if it either won't flow or only trickles, I have even in desperation, carefully used a piece of fencing wire, slid up until the obstruction is felt, wriggled around with the hose poked in from the other direction, water on, until it has dribbled and then let go.
    When it lets go, there is often a ball of rust and gunk best described as looking like a dog turd that will fall out. Flush for a bit longer once this comes out, then reconnect and use a good coolant in future.
    If you have this common blockage in there, you will never get clean coolant until it's been shifted.
    Alan S
    Fellow Frogger! chris's Avatar
    Jan 2005
    Sydney/Marsfield
    376
    Be fun taking them out again next time, won't it? You can buy a Moly anit-seize paste from Repco if you're worried about the copper.
    The only car I've ever worked on that came apart easily had been owned by an engineer (of the fitting and welding type) who put anti-sieze on everything. BEAUTIFUL. Shame we were wrecking it for the engine
    GS 1220 break. Beige cars go faster
    16,756
    Quote Originally Posted by chris
    Like most things I do on these cars, once I have done it the first time for my ownership, I have no problems in the future (probably because I use decent coolant and maintain the cars). Much like rounded sump plugs, horenoudly tight oil filters, gearbox drain plugs that need to be "chiseled" to loosen, spheres that were obviously done up by a 150kg giant with the strength and tools to match....
    Once I've changed them for the first time, all I usually need is a clean rubber glove on for traction and I can undo the filtres/spheres with my bare hands etc....
    Alan, you guys have got to use your heaters more up there !!! I've never experianced that rust problem you speak of
    Shane L
    Bristol/England!
    1,486
    Of course decent quality anti-freeze helps. I know that freezing in Australia is not common, but anti-freeze also contains a corrosion inhibitor.
    Alternativly, just fill with dexron III
    8,923
    Shane L
    Think about it; it's through LACK of use that they get the build up. If they were being used constantly I doubt the problem would have arisn. This car has been laid up so naturally it has the build up.
    The Dexron3 throwaway line should be ignored too before someone takes it serious and gets into some real strife.
    Alan S
    Bristol/England!
    1,486
    Alan S
    Alan, that WAS a joke, a bad one perhaps, but still a joke! john s
    77
    Quote Originally Posted by smiffy1071
    thanks to all for that advice - I have taken it on board (except the Dexron 111 bit - alas I don't have any use for it in my little workshop - mind you I've got plenty of other cans of this and that around) I am going to 'treat' the remaining 2 bolts on the thermostat housing before I take them off.
    Alan when the radiator guy flushed up thru the heater hose a lot of gunk did come out initially and then did run pretty clear. Also I just took the car for a good run down the F6 here in southern Sydney (towards Wollongong - heater and fan on full stopping to check that it was'nt bubbling along the way) and there was no prob. Let it cool a bit when I got home and checked the contents of the overflow tank - looked pretty clear - whereas before I started on it the colour was about the same brown as my Dad's dam water where we catch yabbies! (for the benefit of our English corrospondent a yabbie is an Ozzie prawn that happily lives in fresh to muddy dam water). For the time being I am going to tidy up my workshop a bit - have a little break from tinkering- and then get back to it.
    I am learning along the way. But given that this car has been in storage I feel that I need to check things
    Apr 2005
    209
    Quote Originally Posted by citx2
    We call them craybobs
    cooch
    Fellow Frogger! Ren25's Avatar
    Dec 2002
    Perth
    299
    Stainless bolts are not a solution where alloy is in the mix. Back in the days when I was a grotty yachty we used to use a product called "Duralac" on all stainless fittings onto alloy (masts etc) to stop galvanic corrosion. I have warned also about copper based anti-seize in alloy for the same reason ie galvanic corrosion), a moly or aluminium based equivalent would be the go. Alloy is very touchy stuff and lurks down towards the bottom of the galvanic scale whereas stainless and copper are a long walk, up near the top.
    Mike
    Armageddon was yesterday
    Today we have a problem
    2000 406 Hdi X 3
    2003 307 Hdi
    Member cabbage tree's Avatar
    auckland new zealand
    81
    "(for the benefit of our English corrospondent a yabbie is an Ozzie prawn that happily lives in fresh to muddy dam water). For the time being I am going to tidy up my workshop a bit - have a little break from tinkering- and then get back to it.
    I am learning along the way. But given that this car has been in storage I feel that I need to check things"
    "We call them craybobs"
    "We call them 'Koura' down here in the Land of the Long White Cloud."
    Bristol/England!
    1,486
    Quote Originally Posted by cabbage tree
    That's ok mate, I have my mate from sydney staying with me at the moment, and he can do the trasnslations! john s
