Cheap castor oil for early ID & DS suspension
    melb
    20
    Default Cheap castor oil for early ID & DS suspension
    For all pre 1967 ID & DS (red fluid cars), I've found a very reasonably priced supplier of Castor oil. Several people have told me that castor oil is the best alternative to the red fluid ( LHS), easier on the seals than canola oil and it was even mixed with LHS when this fluid was still cheaply available.
    The company is called Australian Botanical Products Ph. (03) 97964833
    the product is called Castor Oil BP and costs just under $140 for 20 litres.
    Cheers, Hugo
    Fellow Frogger! Paul Smith's Avatar
    Camperdown, NSW, Australia
    624
    Hi Hugo,
    You don't use straight castor oil - see here
    Mark Bardenwerper's notes on LHS replacements
    The mix in warmer climates can be up to 25% I believe
    Paul
    Paul Smith
    1974 DS23 EFI BW Auto
    1974 G Special 1220
    http://www.simplicitas.com.au
    melb
    20
    Hi Paul,
    Thanks for posting that link, I have so much to learn
    I've previously had a supply of LHS which was out of an 1962 ID that I dismantled about 6 years ago. I have only needed to top up the reservoirs in my ID's with castor oil a couple of times ( after excessive suspension leaks)and left the bulk of the castor oil with my mechanic.
    I was wondering about the viscosity difference between red fluid and castor oil, the cars seem to ride smoothly, although my DS21 has more supple suspension (green fluid)
    I've never heard of a DOT4 brake fluid and castor oil mix,
    is the ratio 25% DOT4 or 25% castor oil?
    Cheers,Hugo
    16,754
    Quote Originally Posted by citds67
    Hi Paul,
    There seems to be a wide variation in the price of DOT4 brake fluid. Does anyone know of a reasonably priced supplier in Melbourne.
    Cheers,Hugo
    Hi Guys,
    I think castor oil by itself is far to thick. Definatly use brake fluid with a smaller % of castor oil added. There is a few of use that have been using canola oil for some time. So far it's been ok, however the castor oil/brake fluid mix I feel is probably better (infact I wouldn't be surprised if that's what LHS2 is).
    Your brake fluid DS doesn't ride as well as the green fluid car because the castor oil is thicker, so flows through the sphere valves much more slowly (making the car firmer).
    melb
    20
    Hi All,
    I've purchased the DOT4 brake fluid and taken it to my mechanic.
    He is reluctant to use it because he doesn't know anyone who has tried this blend.
    Does anyone on this forum use a blend of DOT4 and castor oil n their early ID?Has it been successful and what ratio did you find was best?
    I have read the link that Paul posted and will email it to my mechanic, but it would also be reassuring to hear that someone is using this blend without any damage to seals and the ratio they prefer
    Cheers Hugo
