Xsara Oil Filter
    Ballarat
    7
    Default Xsara Oil Filter
    Anyone got a code for the Xsara oil filter? Checked some oil filter manufacturers catalogues and can't find one with the Xsara listed!
    Do you have to go genuine or is there someone who has an 'aftermarket' filter?
    Anyone use any whizz-bang oil? The owner's manual really doesn't want individuals to do servicing yourself - they don't even state what weight oil Citroen recommend from factory!
    Nov 2002
    Yarrabilba, Queensland
    2,760
    Default French Car = Purflux filters
    I have always used Purflux Filters in all my French Cars, right from myR17 when I got it back in 1985.
    French Car care in brisbane stock them, as do Caravelle in Melbourne, and I am sure most other places too.
    Website linky http://www.filtrauto.com/
    Oil filter LS867B....same as my Pug used to be, and will be again soon possibly(has swapped engine atm)
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    16,755
    I've always said that one purflux filter appears to fit every car I own.... We should buy some in bulk. That one filter fits:
    Purflux LS867B
    AX 1.0i 37KW(50PS/HP)
    AX 1.1i 44KW(60PS/HP)
    AX 1.4i 55KW(75PS/HP)
    AX 10 E, RE, K-WAY, SPOT 30/33KW(41/45PS/HP)
    AX 11 RE, TRE, TE, TGE, TRS 40KW(54PS/HP)
    AX 14 Diesel 38KW(53PS/HP)
    AX 14 TRS, TZS, TZX 52KW(70PS/HP)
    AX 15 Diesel 42KW(58PS/HP)
    AX GT 62KW(85PS/HP)
    AX GTi 69KW(95PS/HP)
    AX Sport 69KW(95PS/HP)
    Berlingo 1.1 44KW(60PS/HP)
    Berlingo 1.4 55KW(75PS/HP)
    Berlingo 1.8 66KW(90PS/HP)
    Berlingo 1.8 Diesel 44KW(60PS/HP)
    Berlingo 1.9 Diesel 51KW(71PS/HP)
    BX 14 E, RE, TE, TGE 48/53/55KW(65/72/75PS/HP) 08/88-->
    BX 14 E, RE, TE, TGE 52KW(71PS/HP) 08/88-->
    BX 14 E, RE, TE, TGE 55KW(75PS/HP)
    BX 15 RE, TRE, TGE 54/59KW(73/80PS/HP)
    BX 16 RE, TGE, S, RS, TS, TRS, TGS, TRI 53KW(72PS/HP)
    BX 16 RE, TGE, S, RS, TS, TRS, TGS, TRI 65KW(88PS/HP)
    BX 16 RE, TGE, S, RS, TS, TRS, TGS, TRI 66KW(90PS/HP)
    BX 17 D, RD, TD Diesel 44KW(60PS/HP)
    BX 19 Diesel 47KW(64PS/HP)
    BX 19 Diesel 52KW(71PS/HP)
    BX 19 GTi, GTi 4X4, GTi 16 92/117KW(125/160PS/HP)
    BX 19 Sport 93KW(126PS/HP)
    BX 19 TGS, TZS 78KW(107PS/HP)
    BX 19 TRS, GT 77KW(105PS/HP)
    BX 19 Turbo Diesel 66KW(90PS/HP)
    C15D Diesel 44KW(60PS/HP)
    C15E 1.1 35KW(48PS/HP) 07/88-->
    C15E 1.1 44KW(60PS/HP)
    C15E 1.4 49KW(67PS/HP)
    C15E 1.4i 55KW(75PS/HP)
    C25D 1.9 Diesel 51KW(69PS/HP)
    C25E 57KW(78PS/HP) 11/83-->
    C35 Diesel 50KW(68PS/HP) 07/86-->
    C35, RE 04/86-->
    CX 20 RE, TRE 75/78KW(102/106PS/HP)
    CX 22TRS 84KW(115PS/HP)
    CX 2400 94KW(128PS/HP) 06/82-->
    CX 2400 GTI 94KW(128PS/HP)
    CX 25 IE, GTI, TRI 101KW(138PS/HP)
    CX 25 RD, TRD Turbo 2 88KW(120PS/HP)
    CX 25 RI, GTI Turbo 2 101/123KW(138/168PS/HP)
    Evasion 1.8i 73KW(99PS/HP)
    Evasion 1.9 Turbo Diesel 67KW(92PS/HP)
    Evasion 2.0i 90KW(123PS/HP)
    Evasion 2.0i 16V 97/100KW(132/136PS/HP)
    Evasion 2.0i Turbo 110KW(150PS/HP)
    Evasion 2.1 Turbo Diesel 80KW(110PS/HP)
    Jumper 1.9 Diesel 51KW(71PS/HP)
    Jumper 1.9 Turbo Diesel 68KW(92PS/HP)
    Jumper 2.0 80KW(110PS/HP)
    Jumpy 1.9 Diesel 51KW(71PS/HP)
    Jumpy 1.9 Turbo Diesel 66/68KW(90/92PS/HP)
    Saxo 1.0i 37KW(50PS/HP)
    Saxo 1.1i 44KW(60PS/HP)
    Saxo 1.4i 55KW(75PS/HP)
    Saxo 1.5 Diesel 42KW(58PS/HP)
    Saxo 1.6i 66KW(90PS/HP)
    Saxo 1.6i 16S VTS 88KW(120PS/HP)
    Visa 17 Diesel 44KW(60PS/HP)
    Visa GTi 76/83KW(103/113PS/HP)
    Xantia 1.6i 66KW(90PS/HP)
    Xantia 1.8i 76KW(103PS/HP)
    Xantia 1.8i 16V 81KW(110PS/HP)
    Xantia 1.9 Diesel 52KW(71PS/HP)
    Xantia 1.9 Turbo Diesel 67KW(92PS/HP)
    Xantia 2.0i 90KW(123PS/HP)
    Xantia 2.0i 16V 99/110KW(135/150PS/HP)
    Xantia 2.0i Turbo 110KW(150PS/HP)
    Xantia 2.1 Turbo Diesel D12 81KW(110PS/HP)
    XM 2.0 84KW(115PS/HP)
    XM 2.0i 89KW(121PS/HP)
    XM 2.0i 16V 97KW(132PS/HP)
    XM 2.0i Turbo 110KW(150PS/HP)
    XM 2.1 Diesel D12 60KW(82PS/HP)
    XM 2.1 Turbo Diesel 80KW(110PS/HP)
    Xsara 1.4i 55KW(75PS/HP)
    Xsara 1.5 Diesel 42KW(57PS/HP)
    Xsara 1.6i 65KW(88PS/HP)
    Xsara 1.8 Diesel 43KW(58PS/HP)
    Xsara 1.8 Turbo Diesel 66KW(90PS/HP)
    Xsara 1.8i 66/76KW(90/103PS/HP)
    Xsara 1.8i 16V 82KW(112PS/HP)
    Xsara 1.9 Diesel 50KW(68PS/HP)
    Xsara 1.9 Turbo Diesel 66KW(90PS/HP)
    Xsara 2.0i 16V 97KW(132PS/HP)
    Xsara Coupe 2.0i 16V 123KW(167PS/HP)
    ZX 1.1 40KW(54PS/HP)
    ZX 1.1i 44KW(60PS/HP)
    ZX 1.4 Diesel 38KW(53PS/HP)
    ZX 1.4i 55KW(75PS/HP)
    ZX 1.6i 66KW(90PS/HP)
    ZX 1.8 Diesel Entreprise 44KW(60PS/HP)
    ZX 1.8i 75KW(103PS/HP)
    ZX 1.8i 16V 81KW(110PS/HP)
    ZX 1.9 Diesel 52KW(71PS/HP)
    ZX 1.9 Turbo Diesel 67KW(92PS/HP)
    ZX 1.9i 88KW(120PS/HP)
    ZX 2.0i 90KW(123PS/HP)
    ZX 2.0i 16V 110/123KW(150/167PS/HP)
    ZX 2.0i 16V 112KW(152PS/HP)
    106 1.0 KID 37KW(50PS/HP)
    106 1.0 XN, XR, XA 33KW(45PS/HP)
    106 1.1 Symbio, Equinoxe, Cashmere 44KW(60PS/HP) -->06/98
    106 1.1 XN, XR 44KW(60PS/HP)
    106 1.3 Rallye 72KW(98PS/HP)
    106 1.4 Diesel 37KW(50PS/HP)
    106 1.4 Symbio, Equinoxe, Cashmere 55KW(75PS/HP) -->06/98
    106 1.4 XR, XT 55KW(75PS/HP)
    106 1.4 XS 55KW(75PS/HP)
    106 1.4 XSi 69KW(94PS/HP)
    106 1.5 Diesel 40KW(55PS/HP)
    106 1.6 Equinoxe, Cashmere 66KW(90PS/HP) -->06/98
    106 1.6 Rallye 75KW(103PS/HP)
    106 1.6 XS 74KW(101PS/HP) -->06/98
    106 1.6 XSi 76KW(103PS/HP)
    106 1.6 XT, XS 65KW(88PS/HP)
    106 S16 1.6 16V 88KW(120PS/HP) -->06/98
    205 1.0 GL, XE, XL, Junior, Oceane, Style 33KW(45PS/HP)
    205 1.1 CJ, GL, GR, GE, XA, Junior, Color 44KW(60PS/HP)
    205 1.1 GE, XL, Oceane, Color Line, Look 40KW(54PS/HP)
    205 1.1 GR, XR, XA, GL 36KW(49PS/HP)
    205 1.1 Sacre Numero 44KW(60PS/HP)
    205 1.3 GR, CJ, SR, XR, XRA, Lacoste 44KW(60PS/HP)
    205 1.4 CJ 55KW(75PS/HP)
    205 1.4 CT 58KW(79PS/HP) 08/87-->
    205 1.4 GR, SR, XR, Style 55KW(75PS/HP)
    205 1.4 GT, XS, XT 58KW(79PS/HP)
    205 1.4 Kat., CJ Kat. 44KW(60PS/HP)
    205 1.4 Sacre Numero 55KW(75PS/HP)
    205 1.6 Open, Automatique 53/65KW(72/88PS/HP)
    205 1.8 Diesel 44KW(60PS/HP)
    205 1.8 Turbo Diesel 57KW(78PS/HP)
    205 1.9 Diesel 47KW(64PS/HP)
    205 CTI 1.6 76KW(103PS/HP)
    205 CTI 1.9 75KW(102PS/HP)
    205 GTI 1.6 84KW(115PS/HP)
    205 GTI 1.9 95KW(130PS/HP)
    205 Rallye 76KW(103PS/HP)
    305 1.6 54/66KW(73/90PS/HP)
    305 1.9 72/75KW(98/102PS/HP)
    305 1.9 Diesel 48KW(65PS/HP)
    306 1.1 XN, XR 44KW(60PS/HP)
    306 1.4 XN, XR, SL, SR 55KW(75PS/HP)
    306 1.4 XN, XR, SL, SR 55KW(75PS/HP) -->06/98
    306 1.6 SL, SR, XR, XT, XS 66KW(90PS/HP)
    306 1.6 SL, SR, XR, XT, XS 66KW(90PS/HP) -->06/98
    306 1.8 Diesel 44KW(60PS/HP)
    306 1.8 XT 76KW(103PS/HP)
    306 1.8 XT 76KW(103PS/HP) -->06/98
    306 1.9 Diesel 51KW(70PS/HP)
    306 1.9 Turbo Diesel 67KW(92PS/HP)
    306 16S 2.0 110KW(150PS/HP)
    306 16S 2.0 122KW(167PS/HP) -->06/98
    306 2.0 97KW(132PS/HP) -->06/98
    306 2.0 ST 90KW(123PS/HP)
    306 2.0 XSi 90KW(123PS/HP) -->06/98
    309 1.1 GE, Vital 44KW(60PS/HP)
    309 1.1 XE, GE, XA, Chorus, Graffic, Vital 44KW(60PS/HP)
    309 1.4 GR, GRX, GL Profil, Vital, Best line, Green 55KW(75PS/HP)
    309 1.4 GR, XA, Green, GL Profil, XL Profil 49KW(67PS/HP)
    309 1.4 GRX, Vital, GL Profil 55KW(75PS/HP)
    309 1.6 GR, SR, SX, XR, XS, GRX, Best Line 55KW(75PS/HP)
    309 1.6 GRX 65KW(88PS/HP)
    309 1.8 Turbo Diesel 58KW(78PS/HP)
    309 1.9 Diesel 47KW(65PS/HP)
    309 1.9 GR, XS 80KW(109PS/HP)
    309 GTI 88/95KW(120/130PS/HP)
    309 GTI 16 117KW(160PS/HP)
    405 1.4 GL, GLX 51KW(70PS/HP)
    405 1.4i GLi 55KW(75PS/HP)
    405 1.6 GL, GR, GRX, SR 53/55KW(72/75PS/HP)
    405 1.6 GLi, GRi, SRi, Sillage, Style 65KW(88PS/HP)
    405 1.8 GRi, SRi, Signature, Style 74KW(101PS/HP)
    405 1.8 Turbo Diesel 66KW(90PS/HP)
    405 1.9 Diesel 47/51KW(64/70PS/HP)
    405 1.9 Diesel 47KW(64PS/HP)
    405 1.9 GR, GRX, SR 80KW(110PS/HP)
    405 1.9 Mi16, Mi16 4X4 108/117KW(147/160PS/HP)
    405 1.9 Turbo Diesel 66KW(90PS/HP)
    405 1.9i GRi, SRi, Si, Signature 92KW(125PS/HP)
    405 2.0 16V 110KW(150PS/HP)
    405 2.0 Mi16, T16 110/147KW(150/200PS/HP)
    405 2.0i SRi, STi 90KW(123PS/HP)
    406 1.6 66KW(90PS/HP) -->06/98
    406 1.9 Diesel 55KW(75PS/HP) -->06/99
    406 1.9 Turbo Diesel 67KW(92PS/HP) -->06/99
    406 2.0 Turbo 110KW(150PS/HP) -->06/98
    406 2.1 Turbo Diesel (12V) 80KW(110PS/HP) -->06/99
    406 Coupe 2.0 16V 100KW(135PS/HP) -->06/98
    504 1.9 Diesel 40KW(54PS/HP) 10/81-->
    504 2.3 Diesel 51KW(69PS/HP) 10/81-->
    504 GRD, SRD Diesel 48KW(65PS/HP) 10/81-->
    504 L, GL, GR, SR 58/64/72KW(79/87/98PS/HP) 10/83-->
    505 1.8 GL, GR, SR, SX 55/60/62KW(75/82/84PS/HP) 10/83-->
    505 2.3 GLD, GRD, SRD 10/81-->
    505 2.5 Diesel 51/55KW(70/75PS/HP)
    505 GL, GR, SR, SX 70KW(96PS/HP) 10/83-->
    505 GTI 90/95KW(122/130PS/HP) 09/83-->
    505 Turbo Inj. 110KW(150PS/HP)
    605 2.0 16V 97KW(132PS/HP) -->06/99
    605 2.0 SL 84KW(115PS/HP)
    605 2.0 Turbo 104/108(141/147PS/HP) -->06/99
    605 2.0i SLi, SRi, SRTi, SVTi 90/106KW(123/145PS/HP)
    605 2.1 Diesel 60KW(82PS/HP)
    605 2.1 Turbo Diesel 80KW(110PS/HP)
    806 1.8i 72KW(99PS/HP) -->06/98
    806 1.9 Turbo Diesel 67KW(92PS/HP) -->06/98
    806 2.0i 90KW(123PS/HP) -->06/98
    806 2.0i Turbo 110KW(150PS/HP) -->06/98
    806 2.1 Turbo Diesel 80KW(110PS/HP) -->06/98
    Boxer 1.9 Diesel 51KW(70PS/HP) -->06/99
    Boxer 1.9 Turbo Diesel 67KW(92PS/HP) -->06/99
    Dangel 504 4X4, 504 Pick-up 4X4 79/80/95KW(108/110/130PS/HP)
    Expert 1.6i 58KW(80PS/HP) -->06/98
    Expert 1.9 Diesel 51KW(71PS/HP) -->06/98
    Expert 1.9 Turbo Diesel 67KW(92PS/HP) -->06/98
    J5 1.8 50KW(69PS/HP) 10/83-->
    J5 1.9 Diesel 51KW(70PS/HP)
    J9 2.0 56KW(77PS/HP) 11/83-->
    J9 2.5 Diesel 53KW(72PS/HP) 10/81-->
    P 4 2.0 4X4 10/83-->
    P 4 2.5 Diesel 4X4 10/81-->
    Partner 1.1 44KW(60PS/HP) -->06/98
    Partner 1.4 55KW(75PS/HP) -->06/98
    Partner 1.8 66KW(90PS/HP) -->06/98
    Partner 1.8 Diesel 44KW(60PS/HP) -->06/98
    Partner 1.9 Diesel
    1000+ Posts TroyO's Avatar
    2,514
    What model Xsara do you have? Not all Xsara's use the same filter. The 1.6 16V engines (TU5JP4) use a cartridge type filter for example, where the 1.8L/2L models don't.
    I would stick to using Purflux filters.
    Troy.
    Bristol/England!
    1,486
    Yup, perflux is what we use here, especially seeing as that is genuine original fitment!!! john s
