GS query
Thread: GS query
    Mar 2003
    Location Location
    1,578
    Default GS query
    Hi all
    Just got a '77 GS up and running as a daily driver and it's been tramlining big time. Seems to only do it when accelerating so I'm wondering if it's an engine mount? Mind you it also does it when cruising at a constant speed so I'm not sure what it could be
    It's got one dodgy driveshaft, a few bushes need doing and possibly a ball joint but apart from that it looks oright. I've also swapped tyres around to no avail.
    Anyone got a clue?
    cheers
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Lower control arm bushes?
    Option #2 - Rear arm bearings?
    Option #3 - Wheels toeing in instead of out?
    Alan S
    1,475
    Quote Originally Posted by graham66
    Hi all
    Anyone got a clue?
    cheers
    ...and it's roadworthy?
    Engine mounts were done on said car... but GS's seem to go through them. Easy to source, though.
    1972 SM
    1989 BX 16 Valve
    Fellow Frogger! chris's Avatar
    Jan 2005
    Sydney/Marsfield
    376
    That'll do it... Does it have a worn tie-rod? You'll likely need to fix that stuff first, because you can't even get the wheel alignment right with play in the system
    GS 1220 break. Beige cars go faster
    Mar 2003
    Location Location
    1,578
    Quote Originally Posted by donat
    Schyeah.. nothin wrong with it!
