CX Petrol Tank
Results 1 to 10 of 10
Thread: CX Petrol Tank
    Fellow Frogger! doggiedog's Avatar
    Sep 2004
    gippsland
    126
    Icon8 CX Petrol Tank
    Hi All,
    I Finally took the CX for its Maiden voyage last night, and apart from the Overheating problem, ( another story) all went well, drove great, etc, my first drive not only of a CX but a Citroen.
    This afternoon I took it to the petrol station and filled it up, partly to see if the fuel guage worked, (cos I had my doubts), and yes it does work sometimes, (loose wire on the sender I hope).
    Went out in the Peugeot, came back a couple of hours later and parked behind the CX, and noticed a smell of petrol.
    Looked under the CX and horror of horrors, there is petrol slowly dripping down from the top of the tank, from the filler side right round the back, to the other side. It has only just started to hit the driveway after a couple of hours, so its not a big leak, I'm just puzzled where on the tank it could be coming from, as it seems to be leaking on top of the tank and leaking evenly around the tank.
    Tomorrow I will have to siphon it into a Jerry Can and stick it in the Jag.
    Any Ideas what my plan of attack should be?
    Can the tanks be repaired, or should I source another?
    Terry
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,080
    Sounds like you have a leak from around the fuel gauge sender/fuel pickup and return assembly that goes in through the top of the tank.
    Sounds like a tank out job and investigate - reseal job or just only fill it up to 3/4 full like I do on mine.
    Ken W
    Sep 2004
    gippsland
    126
    On closer inspection in the dark, there were 2 leaks. The main one was from the breather pipe at the back of the tank, which was perished, and had no clamp, and a minor leak from where the filler pipe attaches to the tank.
    I very quickly shortened and put a clamp on the breather pipe, and tightened up the filler clamp, as I had left the suspension up, and as the back slowly sank, the leak got worse!! The car was parked right next to the house, and the gas heater was running about 2 feet away, raised timber floor, petrol fumes !!!
    Its all hosed away now.
    Thanks for the reply.
    Terry
    Fellow Frogger! sdabel's Avatar
    Jun 2003
    216
    Icon11
    Hi Terry,
    I am sure you know this, but hydraulic Citroens can drop very quickly. While it is very tempting to work under them with the suspension up it is not a great idea.
    Enjoy your CX!
    regards
    sean
    _____________________
    1996 XM 2.1 TD Exclusive
    Sep 2004
    gippsland
    126
    I realise this, but the car was down by the time I put the clip on the hose, and I only put my arms under as the overflow pipe is right near the back, but thanks for the warning,
    Terry
    16,748
    Yep,
    very common problem... I've never had a CX that didn't slop over the top. My CX will slop over around corners if I brim the tank (and if I fill on a cold morning then go home and park in the drive on a downhill angle). Most likely you will find yours is either missing the metal insert the cap seals down on, or the plastic section of pipe where you insert the bowser nozzle into is cracked from someone leaning on the filler while they fill the car.
    Sep 2004
    gippsland
    126
    OK, Ill give it a better look over tomorrow, but Ive stopped the fuel from hitting the ground at least, I had visions of 68 litres of petrol under the house in the morning.
    I'll look at that, before I do the plugs, points, fiddle with the timing, change the oil/filter, and hydraulic oil, that'll just about see the day out ( with stuff ups)!!
    Terry
    Apr 2005
    Cootamundra Australia
    209
    Quote Originally Posted by doggiedog
    Terry
    Add an extra half day on to that and a VW mechanics elbow
    Cooch
    Bristol/England!
    1,486
    just as an asside, if you do ever need to drain the tank, there is a drain plug at the front of the tank. It is very easy to drop the tank out altogether if you need to, the sling under it, is only held in by one bolt in the boot lip (not lid). I took the tank out of my scrap 22TRS the weekend before last, and it took just 20 mins, after getting the back end in the air! john s
    Sep 2004
    gippsland
    126
    I checked it the next morning, and its not leaking a drop, the hose clamps did the trick.
    Terry
