Citroen Xsara SXTD 1998 td
    Jul 2004
    IL
    2
    Default Citroen Xsara SXTD 1998 td
    Have A WEIRD Problem.
    Before the problem started, this is the Data:
    90C on hot day, without A/C
    75C On hot day, With A/C
    Today, its
    90C on hot day without A/C
    95C on hot day with A/C
    the Fans are not working as they used to, its not Getting in to 12V Mode.
    only 9V works.
    But, sometimes if you press hard on the gas pedel, or turning on/off the car, they Get intoaction at 12V Speed.
    But quickly shutting down.
    I Suspect in the part on the thermostat house with the brown plug. The engine is DHY Turbo Diesel Engine.
    How can i Detect it correctly??, and if so, What more can cuase the problem?
    thank you.
    1000+ Posts zykyra's Avatar
    Apr 2003
    Perth
    1,199
    Hey mate, I suspect you have not had any replies as their were no turbo-diesel Xsara's sold in Australia. Not sure about NZ though? Thought you might like too know anyway
    1972 DS Pallas
    2015 Clio
    2012 DS4
    Simca Arondes (travaux en cours)
    Lotus Elise Club Racer '12
    In WA? Join THE club ! www.frenchandfantastic.com.au
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Just sounds like it's out of gas to me.
    You'll need to take it to a car air/con repairer as there's nothing that can be done DIY on those systems.
    Alan S
    Jul 2004
    IL
    2
    Default There is no Xsara?
    Xsara is a beuitful car.
    weird.
    well thanks guys, im going to check into it.
