BX rear arm bearings.
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Default BX rear arm bearings.
    Looks like I have a rear swing arm bearing job looking me in the eye in the near future.
    The symptoms at this stage are the occasional creak/crack as I get into the car, ride not as smooth as I would expect, one rear tyre apparently wearing a bit on the inside. I'll replace them before it goes ballistic & starts looking like it's gone all knockneed or begins to gring its way into the actual arms. By doing it before the event, I hope I can get away by using just new bearings but to save the drama of stripping before I go shopping for bearings, can anyone give me some part numbers? I think I have the SKF numbers for a CX and I think (?) a BX is the same. Any clues anyone? Shane???
    Alan S
    Apr 2003
    Kiama NSW
    47
    Alan,
    yep they are the same as CX rear pivot bearings and CX front upper arms too. SKF VKD 23000 if I am looking at the right receipt. I understand new stock may be listed as 24000 but same bearing. Set of 4 set me back $52 plus GST at the local bearing mob.
    Ian
    8,923
    Quote Originally Posted by IanW
    Alan,
    Ian
    Thanks mate; I'll pay cash in the hand & save the 10%
    Alan S
    Melbourne, Victoria.
    1,389
    Alan S
    Hey Alan, I'd be interested to know how you go with this bearing replacement job. I'd like to compare your experience with Shane's one when he did his CX..apparently a real bastard of a job...
    My CX ones are ok for now...fingers crossed.
    Cheers...George.
    Jun 2004
    Denmark
    32
    Have done it both to my CX and a couple of BX'es.
    Shane's picture book is pretty good on the CX job - and covers pretty well the pitfalls also on the BX.
    There are 2 major differences :
    1) on the CX the worst part may well be to loosen/remove the swaybar bolts on the rear (innermost facing) of the arm. Not unlikely to shear the bolts - despite the arm is light alloy.
    Better red heat the bolts - then let cool down before applying torque.
    2) on the BX the problem may in fact be the same - except you round off the boltheads for the swaybar
    Here the boilts are 13mm heads, and holds a bracket that clamps the swaybar to the rear arms from the underside.
    Red heating shows good results here too.
    Note that the bearings may have honed out the arm - despite the arm being steel
    Anyway : NEVER use a hobby 12edge socket - use a 6edge modern type Round Corner socket for sure grip on the bolts - first off
