bx tri 19 can't start
    Jun 2004
    coolatai nsw australia
    5
    Icon11 bx tri 19 can't start
    wanted ignition barrel all the way back to wires as the plastic bit at the end of barrel is broken please e mail or phone on 02 67299076
    Aug 2002
    1,290
    Are these the same as 405 ignition barrels as I have one with key and matching door locks.
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    If it's any help, they are made by "Simplex" and I know from bitter experience there are at least 2 types; possibly 3.
    From memory I think the problem was the number of wires coming from the back end. I replaced one many moons ago & it was a drama trying to get the correct one. I did come to the conclusion that at a pinch it was possible to make one up out of ywo by splitting at the point where the mechanicals and electricals meet but a correct switch turned up before I reached that pont of desperation.
    Alan S
    Jun 2004
    Denmark
    32
    As AlanS - I've had a few time wasters on this
    1.) NO - it's not the same as found in the 405's - or other Peug's for that matter. but MAY be the same as found in other Citroens same production years - EXCEPT the CX model range - which has it's own very unique ignition key barrel.
    2.) The plastic bits (contact set) is available separate as spare from aftermarket suppliers - your local Cit dealer may offer the service of finding a source for this.
    Known as the 2x4pin connector halfmoon contactset
    With barrel out it's a very easy replacement job.
    3.) If you find a new (or s/h) complete ignition key barrell - which fits the hole exactly but not the wiring - then it's a minor problem converting any wiring differences - as the BX electrics are very well documented on the web.
    Jun 2004
    5
    Icon7 thank you your a legend
    thanks for your helpful and informative reply i will be on the hunt for my connector set and hope to be on the road asap
    thanks once more.
    Member Tim Tech's Avatar
    Jun 2004
    Orange NSW
    36
    Secondhand 112.00km BX Ignition Barrel $45 plus postage
    Tim Tech
