C5 brake bleed nipple location
Results 1 to 3 of 3
    Dec 2010
    canberra
    186
    Default C5 brake bleed nipple location
    In working on a 2006 C5 brakes, couldn't find the bleed nipple location, is it cunningly concealed?
    Regards
    agd123
    Jun 2014
    Frankston
    49
    HI,
    Presume you mean the front caliper, the bleed nipple is at the top on the inside, between the cast boss which carries the handbrake outer and the handbrake lever on the caliper, under the handbrake inner it may have a factory rubber cap if you use a mirror it should be fairly easy to locate.
    Dec 2010
    canberra
    186
    I was right is was cunningly concealed, thanks Hydrac your information solved the problem.
    Regards
    Arthur
