DS rear drum brakes overhaul;---questions.
    Jan 2005
    32
    Default DS rear drum brakes overhaul;---questions.
    My 1974 D Special which I have owned and enjoyed for some 30 years has started to leak hydraulic fluid from the rear drum brake cylinders. I have found a source for these as complete units along with new shoes/friction surfaces.
    The drums are of the stated internal diameter (255 mm) but do have some scoring lines; about a millimeter deep. My question is;- can I have the drums lightly machined to take out the scoring and what maximum internal diameter of the drum is allowable?
    I would be grateful to hear from anyone else who has gone down this track.
    If possible I would like to avoid sourcing new drums from overseas (if indeed they are even available) due to the weight factor and the effect on freight/postage costs. Many thanks, Diaron.
    16,702
    I'm easy, I'd repair the boot and just clean the existing linings and re-assemble. The back of CX's and DS's seem to do bugger all work. If its anything like a CX it'll still wear its original brake pads back there
    Jan 2012
    229
    Manual 814 has the drums at 255mm original diameter with a maximum regrind on diameter of 2mm
    10,102
    The wheel cylinders probably only need new O-rings. Take them apart, clean and inspect. You can often clean linings reasonably well and put them back in. The rear brakes last a long time on a DS, so if they are 30+yo linings they are likely asbestos and you need to be mindful of that.
