Citroen DS 23 drain plug
Results 1 to 7 of 7
    Jun 2017
    Queensland
    23
    Default Citroen DS 23 drain plug
    Hi fellow froggies,
    I cannot find the cooling water drain plug on the block of my DS23 engine.
    Help will be gratefully received
    Jun 2015
    Ashburton
    227
    Why not just use the cock on the radiator or just disconnect t the hose on the left side of the radiator
    Feb 2002
    Coolum Beach
    2,048
    Quote Originally Posted by PeterMol View Post
    I use the tap on left hand side of radiator.
    DS Un jour, DS toujours !
    C3 II 2010 Automatique AL4
    Everything's gone bloody automatique!
    Kapunda
    493
    Its near the back of the starter motor.
    Woody
    skp
    skp is offline
    217
    Yes, to the rear of the starter motor... basically inaccessible on the latter motors - and usually clogged internally anyway!
    skp
    Dec 2010
    300
    As others have mentioned, the drain plug is located under the exhaust manifold, behind (i.e. on the cabin side) of the starter motor (see item 4 in the attached image from the Autobook workshop manual). I think it has a 21 or 22mm head and I usually use a ratchet socket handle and a short extension (i.e. between socket and handle) to reach it. It's a bit of a contortionists act to reach and may be a bit tight on first undoing, but I drain my cooling system fairly regularly, using the radiator drain and the block drain and I have no trouble with the latter.
    Good luck.
    Jun 2017
    Queensland
    23
    A big thank you to all who replied to my dilemma.
    I found the little blighter but decided to use the drain cock on the radiator.
