Strange error Codes after replacing battery on C5 x7 2L RHH
Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By dcc236
  • 1 Post By driven
Thread: Strange error Codes after replacing battery on C5 x7 2L RHH
    Oct 2014
    Brisbane/Australia
    409
    Default Strange error Codes after replacing battery on C5 x7 2L RHH
    The car has travelled 1,300kms since the battery was changed last week. Drives as it should. We are now getting some weird codes we can't clear.
    Symptoms:
    - Flashing orange check engine light
    - Cannot set speed limiter or cruise control. (each time it is switched on, it is paused)
    - Remote fob has stopped working
    Codes:
    ECU
    U1318 Intersystems CAN (can't find anything on this I understand using google)
    P0610 Downloading/Configuration (can't find anything)
    BSI
    F5FF Unexpected initialisation fault of BSI
    C98A Engine relay unit: fault front right side light
    C99A Engine relay unit: Fault light side light
    F40A: Oil gauge fault
    I have tried resetting the BSI but now the remote no longer works, not sure what to do. The car is a 2010 C5 x7 2L RHH.
    Anyone have any insights?
    9,031
    To change the battery, you must let the computer snooze after you get out before disconnecting, and let the computer sort itself (reboot) after connection before doing anything. Was this done? If not, do it now. Have a cuppa each time and be certain.
    The computer is never off while battery voltage is present - it detects remotes, key security, doors open, etc. Like desktop computers it must be allowed to close and start properly.
    Oct 2014
    Brisbane/Australia
    409
    We removed battery after car sat idle for 5 mins. We then connected the new battery and did a BSI reset. The remote was working before original battery removal, did not work after new battery install and bsi reset. I also tried a a key fob resynch, switched on ignition and pressed one of the remote butoons for 10 secs and then ignition off, still no luck with the remote.
    Oct 2014
    Brisbane/Australia
    409
    I'm an idiot, who would have thought the remote Fob's battery needed changing. That fixed the remote. Will do another BSI reset tomorrow and see where that leads us
    Kenfuego likes this.
    1000+ Posts driven's Avatar
    Apr 2005
    1,491
    Battery must not be able to understand French
    FIVEDOOR likes this.
    Oct 2014
    Brisbane/Australia
    409
    We successfully complete a BSI reset but we are still getting the following:
    Symptoms:
    Codes:
    ECU
    BSI
    DSG
    U1213 Fault in the vehicle speed information receive by the CAN from the ABS or ESP CPU
    The car is a 2010 C5 x7 2L RHH. Any help with this would be appreciated.
    St Helens Tasie
    611
    I think it would be a good idea to check if you are getting vacuum to the electro valves at the back/top of the motor. The vacuum tubes are easily dislodged if work has been done on the motor.These small valves are so important and are linked to the symptoms you described for the cruise. If you log on to Citroen Service Box and register, you will be able to bring up illustrations of the vacuum circuit. Allan.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,995
    My car has a U1213 fault continuously. I think they all do this and those in the UK say just live with it. I would be happy to be proved wrong by someone who know what to do to cure it.
    Cheers, Ken
