Is there someone that can tell what model xx this gearbox is for GEARBOX Citroen CX 2GE66 NEW
It is advertised on eBay UK and looks interesting if it fits a petrol turbo CX might solve the synchro issues my car has been cursed with
BX 16v 89, I
Renault Floride 62,
Volvo P1800 68,
Aston Martin DB6 68,
Daimler 250V8 68, Jaguar XJC 76, Falcon Ute XL 62,
Falcon Ute XY 4WD, Jeep Grand Larado 03,
Mazda 6 Wagon 05,
inter 483 tractor 86,
makita cordless drill
CX TURBO its dented
D Special 1
62 ID19
2000 Xantia V6
2000 Cadillac STS stolen by the princess,KANGA 720DL LOADER
I looked in the 1981-85 Citroen parts manual and 2GE66 and 2GE65 are for the 2 litre engine after June 1984 (page 197 in the pdf). The GTi Turbo gearbox is marked 2GE60 and 2GE59 (page 200).
Cheers, Marc.
1987 CX GTi T2 Maikonics
1972 SM 2.7 carb
1972 DS21 EFI
Thanks Marc seems that the box is for the dorvrin renault motor
BX 16v 89, I
Renault Floride 62,
Volvo P1800 68,
Mazda 6 Wagon 05,
CX TURBO its dented
D Special 1
62 ID19
2000 Xantia V6
Synchros is no big deal, you can change them through the wheel arch if needed. Have you tried nulon G70 in the 'boxThe later 5spders are quite robust synchro wise. Mine have always been ok'ish. It would have been beaten to death when new as its a CNAN car, so I'm sure the synchros were flogged as hard as the motor when it was new.
'63 ID19http://www.aussiefrogs.com/forum/citro%EBn-forum/90325-best-project-car-you-have-ever-seen.html
'07 Poogoe 407 HDi 6spd manual![]()
It seems from my gearbox guru that the synchro rings themselves are not the issue it is the special treatment to the mating surfaces or the gearset that wear losing the friction component to get them spinning for the meshing
BX 16v 89, I
Renault Floride 62,
Volvo P1800 68,
Mazda 6 Wagon 05,
CX TURBO its dented
D Special 1
62 ID19
2000 Xantia V6
'63 ID19http://www.aussiefrogs.com/forum/showthread.php?t=90325
GS did the same. Their synchros wore quickly. Both the ring and the mating cone wore so that both the gear and the ring had to be replaced. CX C-Matic synchros were of the same design but they are not changed as frequently due to the torque multiplication of the torque converter. Therefore they lasted longer!
Cheers Gerry
