Citroen Berlingo, more power?
Results 1 to 9 of 9
Like Tree5Likes
  • 1 Post By Ken W
  • 2 Post By Demannu
  • 1 Post By Ken W
  • 1 Post By DeKa
Thread: Citroen Berlingo, more power?
    Dec 2017
    14
    Default Citroen Berlingo, more power?
    Is there any way to get more power out a Citroen Berlingo 1.4 petrol?
    Great van but slow as a wet week.
    Not had a wet week in at least ten years.
    Oct 2011
    Sunshine Coast, Australia
    55
    Is it the SOHC?
    As it is probably not.
    Install an induction system from K&N or similar which removes all the factory intake hoses and restrictions.
    This will give you a lot of induction noise.
    Or you could install a turbo.
    Rev the crap out of it.
    Sent from my SM-G920I using Tapatalk
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,046
    What fuel are you using?
    If you are using straight unleaded, it might be retarding the ignition a lot, especially at low revs. Try a full tank of 98 octane and disconnect the battery for 30 minutes or so to reset the ECU. This process gives the 2 litre 16 valve Xantia engine a large amount of low speed torque that gets lost when running on unleaded 91.
    Cheers, Ken
    Jingle Berry likes this.
    Dec 2002
    Menzies Creek
    2,555
    Armidillo and FIVEDOOR like this.
    Scotty
    Melbourne - Dandenong Ranges
    1999 Peugeot 406 Coupť - 'Chloe' - 5 speed manual
    2014 Peugeot RCZ - 'Remy'
    Armidale
    2,547
    There's nothing that can't be fixed by a V6 .
    Aug 2016
    Sunshine Coast, QLD
    935
    Add a turbo or super charger, don't all the 1.2 and 1.4 engines have these fitted now?
    Dec 2017
    14
    Ken W,
    I might try this as i always put low octane fuel in it.
    How does the engine sense the change in fuel?
    Otherwise it is great but so slow.
    V6 conversion would make it a death trap.
    North Brisbane
    2,046
    The engines have a knock sensor that detect any pre-ignition and retard the spark until it stops. You might be able to get away with 95 octane but try a tank of 98 to see if you can get some more low speed torque.
    Cheers Ken W
    May 2001
    Sydney, NSW, Australia
    3,638
    How old and how many kilometres?
    New O2 sensor(s) if itís got more than 100,000km and 98 octane fuel should help.
    That means itíll advance the timing as much as possible on the 98 octane fuel.
    Bosch O2 sensor parts appear to be as follows for 2008->
    Upstream 0258006028
    Downstream 0258006185
