Light 15 scraping thrust bearing ??
Results 1 to 7 of 7
Like Tree7Likes
  • 4 Post By 59 Floride
  • 2 Post By gerrypro
  • 1 Post By robmac
Thread: Light 15 scraping thrust bearing ??
    Jul 2004
    Castlemaine Area
    490
    Default Light 15 scraping thrust bearing ??
    A friend has got a light 15. He says that when he pushes the clutch pedal there is like a scraping noise which I would think is a faulty thrust bearing. He inserted oil in an oil cup near the bottom fan belt pulley but this isn't making it any better. - - - Any clues ??
    John
    It's how I roll...Brisbane
    33,470
    is the family cat accounted for..?
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,103
    Quote Originally Posted by gilberthenry View Post
    John
    Get the engine and gearbox out and separate the bell housing and crank case and have a look. The bearing may have collapsed. the tin shield may be loose or it may even be an odd ball bearing stuck in as a replacement. It is possible to use a VW bearing as a replacement but the tin shield needs modification to prevent it rubbing on the clutch fingers. Who knows until you have a look!
    Dano and Kenfuego like this.
    Cheers Gerry
    19,211
    In times gone by I'd probably have pulled the engine and had a look as per your suggestion.
    These days, with reasonably priced inspection cameras available I would probably have a look with a camera first.
    Kenfuego likes this.
    Oct 2002
    Melbourne Victoria
    12,125
    Good Idea as it could well be rubbing on the clutch fingers as described by Gerry.
    3,103
    A Light 15 engine out on the floor in an hour and a half! The problem will need to be fixed so it has to come out no matter what!
    Cheers Gerry
    Jul 2004
    Castlemaine Area
    490
    Thanks for that - - looks like the engine will come out - - lots of fun !!! ???
