Traction Starter Motor Issue
  • 1 Post By gerrypro
Thread: Traction Starter Motor Issue
    Mar 2017
    Bawley Point
    20
    Default Traction Starter Motor Issue
    Hi All,
    Having an issue with our 1948-50 Traction starter motor.
    Starter motor is turning over but not engaging to start engine.
    The shaft at the rear of the motor is spinning but a sort of grinding noise is coming from that area.
    Any advice much appreciated.
    San Diego, California, USA
    3,492
    The grinding noise is likely the starter pinion grinding on the flywheel's edge. Literally- stop doing that. If you continue, your next step will be replace a hard-to-find flywheel. It sounds like the Bendix drive has failed. Your best bet is either take it to an electrical shop you can trust, or buy a replacement rebuilt.
    One thing I would do before all that though is make sure the bolts holding the starter in place are cinched up. I have seen on other cars where the bolts are loose, causing tooth misalignment.
    Brisbane Australia
    161
    I had a similar experience the other day with the motor out of my TA BL. I bought a new battery (6Volt French car) problem immediately solved.
    Cheers.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,010
    British TA or French TA??? The starter pinions are quite different. British is Lucas, and French can either have Bendix or Benada pinions. If French the Ford A model Bendix drive is a viable replacement!
    Hotrodelectric likes this.
    Cheers Gerry
    Mar 2017
    Bawley Point
    20
    Thanks everyone, the car is a French built TA, battery is not an issue, have stopped cranking the starter and will check if bolts are not up tight. If the starter has to come out are there any tricks l should be aware of.
    Thanks again.
    3,010
    On an 11BL it is easier to remove the manifold to gain access to the starter. With an 11 Normale there is more room to clear the underside of the exhaust manifold.
    It is possible to remove the starter on an 11BL without removing the manifolds but it requires jacking the motor and undoing the rear engine mount. To get at that one needs to remove the carpet and then one can see the rear mount housing to remove it and then the rubber mount block. Even having done this clearance is tight and if you have a decent engine bay inish it may well be damaged. My advice------ remove the manifold first. While the manifold is off check the mounting faces with a straight edge to ensure that they are all in a single plane. Manifolds do warp with age. They can be rectified by machining and checking against a surface plate. Renew the gaskets and refit!
    Cheers Gerry
