Aussiefrogs
Results 1 to 17 of 17
Like Tree10Likes
  • 2 Post By dmccurtayne
  • 1 Post By GreenBlood
  • 5 Post By Roger Wilkinson
  • 1 Post By dmccurtayne
  • 1 Post By Nagaman
Thread: Aussiefrogs
    Aug 2015
    Nagambie
    1,386
    Default Aussiefrogs
    Can someone explain to a tech challenged one exactly what happened to the aussiefrogs app use (on an iPad at least)......will it ever work again?.
    Sent from my iPad using Tapatalk
    8,133
    Quote Originally Posted by Nagaman View Post
    I use a PC laptop but just checked both the official AF app and Tapatalk app and both work fine on an old iPad I have here.
    What issues are you having, I note your post is via the Tapatalk app.
    08 C5 X7 HDi very Noir
    Jul 2013
    Newcastle/ central coast
    1,673
    Should ask for a refund
    Garage C5 X7 3008 XTE
    Fix it right the first time
    andrewj and Kenfuego like this.
    Sep 2003
    North Parramatta
    3,986
    Apps need updating (by the developer). Perhaps no one wanted to update it?
    What are the benefits of using the app over, say the Safari version on a phone, or Tapatalk?
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Dec 2010
    canberra
    166
    I previously posted the problems with the search system, has never been fixed by the system organiser as far as I can tell. It really must be fixed, having a system that does not work easily is very poor form & will put off new people especially, they will just leave a group with such poor organisational infrastructure & never return, nor will they recommend the site to others.
    agd123
    8,133
    Icon3
    Quote Originally Posted by agd123 View Post
    agd123
    You've asked the same question several times and had the same answer by several members including myself.
    The search function works well and is quite accurate with the correct search terms. . .
    Forget the search via the drop down menu, it's broke and has been for a decade with no easy fix.
    Instead use the google search at the top of the page i.e.
    Enter your search terms into the search google box and press enter.
    Edit: using your username as search term gives 88 results in a few seconds. . .
    http://www.aussiefrogs.com/forum/goo...859-1&q=agd123
    PeterMol likes this.
    Armidale
    2,279
    I disagree about the Forum search. I use the Advanced Search function in the Nav Panel, as it allows me to fine tune the search (eg choose a particular poster or thread starter as well as a keyword. I choose "Search Single Content Type" (Multiple is the default), and have reasonable success.
    HOWEVER, it has blind spots. For example, it will happily return results if I search for 'Xantia', but return nothing if I search for 'XM' .
    It's not only on AF that Google may work better than the builtin search tool - I used to find what I wanted on Microsoft's Tech Support site far more quickly using Google than Microsoft's own search tool.
    Alec
    8,133
    Alec
    That's interesting Alec, I gave up using the forum search from the drop down menu because it was too frustrating - I do know that simply searching XM, CX, BX etc. would yield no results as it deems the search term too short.
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,293
    My memory is that a 3-letter word was the minimum length you could search for via the drop-down thingo, unless the administrators specified particular 2-letter words that could be searched. I recall a discussion where we suggested 2-letters words we would like to be able to search for, including many Citroen model names. That functionality might have been lost in one of the upheavals along the way.
    I'm not complaining: I get more than I pay for here!
    Roger
    Fellow Frogger! 505604's Avatar
    Junee, NSW
    680
    There are two different apps? I never knew.
    And until I read this post and it tells me ‘Sent from my iPad …’, I’m not sure which one I have!
    Current cars: Peugeot 307 HDi Touring; Peugeot 306 Cabriolet; Peugeot 406 HDi, Peugeot 505 Familiale
    Previous cars: 1965 Peugeot 404; 1972 Renault 16TS; 1970 Peugeo 504 1800; 1978 Peugeot 504 GL; 1976 Peugeot 504 LTI; 1984 Peugeot 505 Familiale; 1982 Peugeot 604 (converted to TD) 1999 Peugeot 306 Cabriolet
    Aug 2015
    Nagambie
    1,386
    This is what I get -
    Jul 2013
    1,673
    Clear the cache and close the app should solve that
    Nagaman likes this.
    Aug 2015
    Nagambie
    1,386
    Cleared history and data but I get this also -
    Jul 2013
    1,673
    Did you go into settings in the app and clear the apps cache
    Aug 2015
    Nagambie
    1,386
    Quote Originally Posted by dmccurtayne View Post
    I have now done that too .
    Aussiefrogs seems alive again.
    Ta muchly
    Feb 2002
    Coolum Beach
    1,863
    Ta muchly
    Obviously the data was packed as tight as a can of sardines!
    DS Un jour, DS toujours !
    Aug 2015
    Nagambie
    1,386
    Quote Originally Posted by harrisson_citroen View Post
    Tech incompetence is my specialty. Age is my excuse.
    jo proffi likes this.
