Xantia CT brake calliper help please.
    Coffs Harbour, NSW, Australia
    625
    Default Xantia CT brake calliper help please.
    I am trying to remove a front brake calliper from my CT. The bottom retaining bolt is T55 Torx, but the top is a strange different Allan key bolt. It is larger than anything I have in my tool kit & it would be helpful if I knew the size before shopping for a new socket key. On my previous cars both bolts were T55 Torx.
    Richard
    Dec 2010
    canberra
    178
    How many sides does it have? I vaguely remember a bolt I had to remove, may well have been on a calliper, was 5 sided. I got a special socket set at a car place which had all sorts of odd sockets & keys including the 5 sided one. Probably not relevant but worth a check.
    Regards
    agd123
    Armidale
    2,540
    I'm afraid you might be on your own there Richard - my guess is that the bolt in question is not original. Had a look at the Activa caliper while I was under there - two identical torx bolts.
    Also I have some memory of tinkering with my Series I Turbo CT's brakes - no special tools required. In fact I once lost that top caliper bolt, and the caliper flopped forward and locked the wheel. Fortunately I was close to home, and was able to reverse for the few hundred metres to get me there.
    Didn't have to order a new bolt - knowing that my neighbour took her dog for a daily walk down our dead end (gravel) road, I let her know I'd lost a bolt. Sure enough, within 24 hours she'd found it!
    Pretty sure the story was that I'd had that caliper off, and probably hadn't tightened that bolt enough - certainly hadn't used Loctite, which I did the 2nd time!
    Do you have a packet of Bluetack (or a recipe for playdough)? Perhaps you could make a mold from the odd bolt head.
    Alec
    9,331
    The illustration of the caliper in a French manual I have shows two Torx bolts. As a guess I'd say one has been replaced with something like an Unbrako (Unbrako brand has a black finish). These use a hex driver. If you have a set of Allen keys, fit one then get a matching size 1/2" or 3/8: drive hex key. Easy to find and inexpensive. The sump plug key might even fit.
    Newcastle
    2,755
    Hi Citroenut
    There is another socket head type that is used sometime, it is a spline drive. Perhaps someone has put in one of them, i have found them on German cars. I bought a set of bits years ago that has Torx, hex, spline, and maybe some other type also. The spline bits have 8 splines. I have ground a hex key to put grooves in the flats to allow it to be used on a large spline drive bigger than my largest bit.
    You can see them in the first ebay page. The second page is similar to the set I have which I bought locally at a tool shop years ago.
    Jaahn
    https://www.ebay.com.au/itm/Spline-B...gAAOSwVYhb0zeS
    https://www.ebay.com.au/itm/SP-Tools...AAAOSwlddceKqv
    PS be careful of using an incorrect bit as you may not be able to get a socket head bolt out if you strip the internal head and it is tight and has had a strong grade locktite used.
