What tyre pressures do you run in your DS?
Like Tree3Likes
  • 2 Post By fritzelhund
  • 1 Post By 4cvg
Thread: What tyre pressures do you run in your DS?
    Feb 2002
    Coolum Beach
    1,863
    Default What tyre pressures do you run in your DS?
    I definitely know what they're meant to be.
    But wondering what the majority here use on their cars.
    It seems every tyre shop nowadays pumps every tyre to 38 psi. I tried it in the C5 , and to my surprise, it's actually still comfortable.
    Would the DS also benefit from higher pressures in the "lookalike" michelin/retro nankang?
    DS Un jour, DS toujours !
    Melbourne, Australia
    275
    I think running higher Tyre pressures on the front tyres will increase the weight of the steering feel. I run with the pressures recommended by Longstone Tyres.
    1974 Citroen D Special (Blanc Meije)
    1989 Citroen 2CV 6 Dolly (Plum & Custard)
    Previously owned Frenchies -
    1976 Citroen GS 1220
    1997 Peugeot 306 XSi
    1995 Citroen XM Series II V6 (Vert Vega)
    Mar 2005
    853
    Quote Originally Posted by gsowner84 View Post
    I disagree with that statement. I looked in the DS21 handbook which suggests 27 PSI front and rear. ( size 185X380 mm tyres ... fitted front and rear on export cars ).
    I believe a higher pressure 32 to 34 will give sharper steering response and be a little lighter at parking speeds.
    Back in the days of ID 19s ( on 165X400 Michelin X Stop pattern ) the recommended pressure was only 24 front and 20 rear which resulted in many "you've got a flat tyre Mister" comments....and huge biceps....but of course no power assistance. While CXs will regularly run out of steering assistance a DS with less than optimum accumulator performance will run out too, especially at parking speeds.
    gsowner84 and dee see like this.
    Feb 2002
    Coolum Beach
    1,863
    Quote Originally Posted by fritzelhund View Post
    Yes , I am running the front at 34 at the moment, it seems to give a good compromise between steering lightness and comfort. Although I know it is a fair bit higher than recommended.....
    275
    I am more than happy to be corrected on this. I have only had a D for about two years. Be great to hear about what other drivers use as ideal Tyre pressures.
    Feb 2005
    rosevale/tasmania
    2,703
    Four comments:
    First, it is correct that higher front pressures will result in lighter steering effort owing to a smaller contact patch to squirm around.
    Second, just upping front pressures will change the handling balance (less understeer, more eager turn in, greater tendency to lift-off oversteer).
    Third, the faux-XVS is structurally different to Xas or XVS Michelins. Differently structured tyres have different handling balances even if on the same pressures & some front-rear pressure differential playing around is in order to get the balance one desires if fitting a different tyre type. The point is more pronounced if the decision has been made to move from poor tyre types (Xas, XVS, faux-XVS) to superior ones like 195/65-15 Continental PremiumContact5 tyres.
    Fourth, most manufacturer recommendations bias tyre pressures towards comfort & towards an understeering handling balance (safer for poor drivers). Thus a usual recommendation is to up pressures absolutely & up the fronts relatively.
    cheers! Peter
    antonio likes this.
