C5 X7 complete key replacement (blade, shell, electronics)
Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By rmac
  • 1 Post By dieselman
  • 1 Post By dmccurtayne
Thread: C5 X7 complete key replacement (blade, shell, electronics)
    Feb 2014
    74
    Default C5 X7 complete key replacement (blade, shell, electronics)
    I am not having very much luck with my Citroen's keys of late. I am somewhat fussy about not losing keys but someone who shall remain nameless in my household isn't quite as assiduous. Well it can happen to any of us I suppose.
    So one of the two keys for my car has been lost. I want to replace it. The key that was lost is the better one of the two - the remaining key has worn through the rubber button covers on the shell and the key blade 'stick's and has to be prised out of the shell. It will be a candidate for a replacement shell soon. I want to get a spare key before I do that, in case my luck goes further downhill.
    Go to a Citroen dealer for a new key you say. I will do that, but I will be surprised if it doesn't cost more than $500 for a replacement chez Citroen. I hope to spend less than that.
    Has anyone replaced their C5 X7 key using an alternative supply source? I once found a UK website that would supply a complete key, only needed a locksmith to cut the blade and set up the electronics to match your car.
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    748
    What year/model of C5 are you needing the keys for? My 2011 C5 X7 sedan keys are different to my 2016 C5 X7 wagon.
    UFO likes this.
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    Aug 2005
    Merimbula, NSW, Australia
    321
    Take a look at polmex.com.au.
    The Citroen X7 key fob is not listed, but it is the same as the Peugeot 3 button fob.
    Easy replacement for the button cover.
    Also, you can buy complete keys with transponder chip from Alibaba.
    I bought a couple, they arrived the other day.
    Quality appears good, but I haven't had them cut or programmed as yet.
    Sent from my LG-H930 using Tapatalk
    Sans_sagesse likes this.
    Leon
    1987 Peugeot 505 GTD
    2010 Citroen C5 3.0 V6 HDi
    Jul 2013
    Newcastle/ central coast
    1,761
    The 407 key is not the same as the c5 one the blade is different you need to get a wide blade with the lights on centre button unless you have a late wagon if you get cheapies from China land some times you need to change the signal type in the bsi and thus need too replace both keys at the same time. Iíve had plenty of upset customers that canít understand why their cheap key is going to kill their old ones.
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Feb 2014
    74
    Quote Originally Posted by dieselman View Post
    The only complete keys I can see on Alibaba have the battery housed in the shell half. Mine is fitted on the transponder board itself.
    As an aside, the other day I had a closer look at the key blade I had cut (on a new China key shell, with the intention of using the original Citroen transponder board) and the grooves on the sides were cut longer down the shank than the original. I wonder if that's why the key wouldn't turn in the ignition (but did in the door).
    I'll have to dig deeper on this during the week. In the meantime just hope that somehow the original key turns up, even though we've looked everywhere. I was going to tag the keys before going away for work but ran out of time. A problem when you need to move one of two same model cars in a hurry and just grab the 4 identical keys to work out which opens what...
    Aug 2005
    321
    Here's a link to the complete key I bought.
    AU $11.59 16%OFF | DJBFANDEA 3Button Remote Key for PEUGEOT Partner 807 307 207 407 308 CC Expert SW For CITROEN Berlingo C3 C2 C5 C4 Picasso
    https://s.click.aliexpress.com/e/dG6UxhW
    Leon
    Aug 2005
    321
    Polmex replacement button cover.
    Leon
    Jul 2013
    1,761
    When coding if the remote doesnít work you will need to go into bsi and change the MHz of the remote
    Feb 2014
    74
    The link you gave above just opened the home page but I pasted in the description you gave above and it offered up a page with the key like mine... I think. Thanks for that, I was searching page after page but couldn't find the board with battery as above.
