Citroen C5 Thermostat housing Removal
    Preston, Melbourne
    258
    Default Citroen C5 Thermostat housing Removal
    Hi, I have a 06 2.2hdi and am trying to remove the housing/outlet tank. I've done all the connections bar the return pipe on the back that runs around the rear of the engine. It is a push on type but the pipe is male rather than the usual female and I can't feel any clips holding it in. What is the correct way to detach it?
    Here's some pix of the part:
    Thanks,
    Leith
    06 Citroen C5 Estate 2.2 Hdi Auto
    95 Peugeot 306 S16
    95 Silver Xantia VSX - now deceased
    8,535
    I have never done a 2.2, but another PSA engine (1.6 petrol) is sealed like this: Screenshot-2.jpg
    6,248
    Leith, I just did a timing belt job on my 206 and it has a similar setup going into what in my case was the plastic water pump around the back of the block.
    The pump has a flange exactly like the the part you arrowed and a metal pipe inserts into it using an o-ring BUT has no retaining clip; it's held only by the parts being securely located. To clarify, the water pump is bolted to the block and the pipe is bolted to the head at the other end, so you just lubricate the mating parts (I used silicon paste) and insert.
    The o-ring on the pipe fits into a groove right on the end of the pipe and seals really well even though they just slip together without any retaining device. Maybe yours is the same, unless you've already loosened everything and it's still stuck of course as mine came apart fairly easily by just pulling the pump.
    2003 PEUGEOT 206 GTi
    Preston, Melbourne
    258
    Thanks, that's what I suspected. However I didn't want to end up breaking anything! I think I will need to remove the studs that the housing goes on to so I can wiggle it a bit more to get it free. I Have added an image of the pipe for reference.
    95 Peugeot 306 S16
    6,248
    That's it! Same setup. I think it reaches far enough in to press upon the part where it narrows in the female end, but I'm not sure. It doesn't leak though!
