DS3 service light
Results 1 to 11 of 11
  • 1 Post By seasink
Thread: DS3 service light
    Mar 2005
    Port Denison WA
    17
    Default DS3 service light
    Hi. I had the service light come on with my ds3. the aircon stopped working at the same time. Initially thought it was due to the harmonic balancer, which has been replaced. fuses are all good, aircon has gas and the compressor is activating. No codes are coming up through the OBD port.
    Any ideas?
    2011 Citroen DS3 Sport 1.6THP
    1997 Citroen Xantia Estate
    8,311
    It's a conventional AC system, so your local place should be able to diagnose it. If the service light is on, an OBD code should have been registered. Does the inside fan run on heating, or on unconditioned ventilation?
    Jul 2013
    Newcastle/ central coast
    1,466
    Make sure the turbo water pump fuse 10a engine fuse box isnít blown canít remember what one this will cause ac to turn off the variable swashplate
    Garage C5 X7 3008 XTE
    Fix it right the first time
    8,311
    According to the owner's manual:
    F21 5A Fan assembly control supply, ABS/ESP, turbo pump (THP).
    Under-bonnet fuses.
    dmccurtayne likes this.
    Mar 2005
    Port Denison WA
    17
    definitely something to do with the fan assembly. replaced fuse and new one blew immediately. auto sparky coming to look on Thursday.
    Jul 2013
    1,466
    It will be the turbo water pump save your money the turbo water pump is near the oil filter two pipes one plug disconnect the plug and replace the fuse should be ok till you can replace
    8,311
    The pump is hard to spot in the tight compartment of a DS3. It looks like this:
    Newcastle
    2,508
    Hi
    Maybee you have the answers from some AF experts.
    But just a comment on the service light again. If the service light is on there is a code(s) to say why it is on and probably more information too. If you cannot read any it is because you have not got a correct code reader. The port is not OBD2 but EOBD and simple readers may not give correct answers or no answers. Sorry but do not believe all you read from sellers on ebay.
    Jaahn
    Mar 2005
    Port Denison WA
    17
    I would have never have thought of the water pump as it is running cooler than normal.
    Jaahn - not using an eBay reader, the auto electricians machine couldn't find a code either. unfortunately nobody within 400kms with a specific reader
    Mar 2005
    Port Denison WA
    17
    Armidale
    2,174
    Re the water pump - David is saying the turbo water pump. This is quite separate to the water pump that circulates the coolant and keeps your engine cool. Pretty sure that the main water pump is not visible, and is driven by a belt, so has no electrical components whatsoever, whereas the turbo water pump is a small pump driven by an electric motor.
    Alec
