brakes siezed
Thread: brakes siezed
    Nov 2014
    ashburton nz
    25
    Default brakes siezed
    hi guys
    havent used the light 15 in sometime but when i tryed to back out of garage other day
    found the brakes had siezed anyone have a quick fix for this or do i have to pull everything
    to bits cheers
    Apr 2014
    Phoenix, Arizona USA
    645
    Possibly you can back off the cam adjusters and get some movement?
    John T.
    Fellow Frogger! Trading Estate's Avatar
    538
    Wheel cylinders might have seized a bit or a film of rust binding the shoes to the drum. I would do what CE said and do a bit of heavy duty rocking! (car in neutral please!) before pulling them apart altho that may be an eventual consequence. Maybe tap the back or side of the drum with a hammer.
    '04 Megane
    Gone but not forgotten
    '71 16 TS, '72 16 TL, '74 15TS,'82 20TS Series 2, '85 25 GTX. '49 L15,
    tweed heads
    1,461
    If it was left with the handbrake on ,try flexing the ,outer sheave of the cable with the brake off ,to free the inner which may have rusted or jammed ,jack it up one wheel at a time to determine which wheel is the problem .pugs
    Nov 2014
    ashburton nz
    25
    thanks guys will get back to you on progress .
