C4 gearbox mount.
    1000+ Posts arunine's Avatar
    Port Denison WA 6525
    1,044
    Default C4 gearbox mount.
    Watching a youtube video on changing a 307 gearbox mount. It says to take the tube out of the old mount and put it to the new one before fitting.
    I had my mounts changed last year and now there seems to be contact between the motor and body, but nothing is apparent. There is vibration through the car and sometimes the gears are hard to shift.
    I have removed the battery/gearbox mount twice to check and still have the problem.
    Any ideas or suggestions? That aforementioned tube does not seem to be there.
    Cheers.
    DS 21
    C4 HDI
    Piaggio Fly 125
    Jul 2013
    Newcastle/ central coast
    1,639
    If that spacer doesnít go back in the mount will last no time at all
    Garage C5 X7 3008 XTE
    Fix it right the first time
    1,044
    It seems the only way to acquire this spacer is to buy the mount and base plate.
    What do you think?
    Cheers.
    DS 21
    C4 HDI
    Piaggio Fly 125
    Jul 2013
    1,639
    Yes or a wrecker they donít wear much at all and most are the same
    Jul 2013
    1,639
    181429 is one of the part numbers for the spacer but I was wrong there are 3 types
    6,248
    The top/central nut won't tighten down without the tube will it? You might have a bit of extra movement there I think.
    2003 PEUGEOT 206 GTi
