DS23 tacho and speedo
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Hotrodelectric
  • 1 Post By Secretsenor
Thread: DS23 tacho and speedo
    Jun 2016
    Newcastle NSW Australia
    118
    Default DS23 tacho and speedo
    Both tacho and speedo seem to have stopped working together...
    earth issue?
    8,131
    Quote Originally Posted by Secretsenor View Post
    earth issue?
    Speedo is mechanical, have you recently removed the instrument cluster and not refitted the cable? There is a second cable join at around the front right hand sphere check it too. . .
    08 C5 X7 HDi very Noir
    "Dťesse" Roland Barthes, 'Mythologies', 1957
    The Dťesse has all the characteristics of one of those objects fallen from another universe that fed the mania for novelty in the eighteenth century and a similar mania expressed by modern science fiction: the Dťesse is first and foremost the new Nautilus.
    Jan 2012
    125
    The tach takes a signal from the coil so itís possible the wire has come loose. Itís a bit strange for them to die together, have you done any work on the car recently?
    Jun 2016
    118
    Tachometer is now operational.
    Is there a trick to getting the speedo cable secured into the gearbox?
    San Diego, California, USA
    3,492
    Yah- on the drive end of the cable there will be a semi circular cutout around the circumference of the flange. Insert the cable into the transmission, lining up that cutout with the bolt hole next to the opening, then insert a bolt (sorry- I forget the size) and tighten it down. IIRC there is also an o-ring present to prevent oil leakage. Ensure that's present and in good shape.
    UFO likes this.
    Jan 2012
    125
    If the cable wonít insert fully, rotate the end of it so that the cable end lines up with the slot in the drive cog. If you can pull the cable out of the gearbox with the bolt in, it hasnít engaged with the drive cog.
    Jun 2016
    118
    Ahhh. Ok. Iíll check it out tomorrow. There has been an oil drip after warming the car up
    Jun 2016
    118
    When I say tomorrow of course I mean in a fortnight.
    Can anyone advise on bolt and o-ring size?
    Jan 2012
    125
    Think the bolt is an M9, needs to be fully removed to release / seat the cable. Parts manual doesnít show an o-ring and I donít remember seeing one when I redid the cable recently
    Jun 2016
    118
    Ok. Thanks!
    I learnt through trial and error that you need to get the bolt right out to get the cable properly seated.
    The bolt looked fairly specific for the purpose.
    UFO likes this.
