2CV6 Headlight Bulbs
Results 1 to 13 of 13
    Feb 2011
    230
    Default 2CV6 Headlight Bulbs
    Hi can they be got from Australia
    Or will I have to go overseas
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,155
    Pull one out and go to Repco and see if they have one.
    John
    Feb 2011
    230
    Default Hi John
    John
    No nothing with that low 45/40 Wattage
    and they don't have any bulbs
    with that P24t or is it P42T metal base
    What wattage are you guys running ?
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,971
    Try this guys website.
    About Classic & Vintage Bulbs
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Feb 2016
    North Yorkshire
    99
    Hi Renburg,
    if you've got original fitment reflectors, it's P45t bulbs which you need, fairly easy to get hold of over here, although it's well worth opting for the 55/60 halogen version.
    Note that the awful dim-dip setup used on RHD 2CVs from the mid-80s onwards should be disabled to prevent damage to the light switch, whichver type of bulb you use.
    https://www.ecas2cvparts.co.uk/-c-69_89.html
    Also, some dodgy dealers have been known to fit aftermarket reflectors, which are set up for LHD use only and take H4 P43t bulbs...
    https://www.ecas2cvparts.co.uk/-c-69_84.html
    Quote Originally Posted by Renburg View Post
    Coffs Harbour, NSW, Australia
    615
    If you go above the original wattage, fit relays or you'll cook the light switch. Relays are a good idea anyway even with the originals.
    Richard
    Feb 2016
    North Yorkshire
    99
    Richard, not in my experience.
    Bear in mind that the same light switch was used in earlier cars, with 6 volt systems.
    The headlamp bulbs in those were rated at 40/45 watts, so the current on main beam would have been 18amps, compared with just 10 amps for a pair 55/60 halogens in a 12 volt system...
    Quote Originally Posted by citroenut View Post
    Richard
    Feb 2011
    230
    It came on again
    It has a broken wire in the bulb that comes on sometimes
    its resting on that sort of flat plate inside the bulb
    615
    Ken I qualified my recommendation with " if you go above the original wattage " ! I'll leave it up to your imagination as to how I know.
    Richard
    JBN
    JBN is offline
    8,155
    It came on again
    Drive slowly at night on smooth roads so you don't disturb its rest.
    Also, make sure the bad bulb is on the passengers side, as oncoming motorists don't mind the left hand light winking as they think it might be a come-on from a female passenger.
    John
    Oct 2002
    Melbourne Victoria
    11,577
    Would be handy if a picture of the required bulb, its base size etc, if it is single contact or double contact (most likely) and 12 volt or 6 volt system. Tucked away in the garage is the remainder (left overs) of light bulbs I used to sell at Bendigo. Not easy to get to, so I don't often go looking anymore except to supply those that know. Most I keep just to supply my own cars, but you never know..
    There are still suppliers of NOS globes around, not as many as the past and some want a fortune for the junk they have. most of mine used to be sold for $4 a headlight globe or $2 for a stop tail and I used to discount for quantity, but I don't do that now.
    Anyway I think if you ask around in your own town, or car club, you will find many willing to help. Don't pay huge prices tho.
    Ken
    JBN
    JBN is offline
    8,155
    Oct 2002
    Melbourne Victoria
    11,577
    I am pretty sure without looking, that I do not have any H4 globes among my Old stock, predates the Halogen type globes. thanks John.
