DS gearbox tools
  • 1 Post By Nigel
Thread: DS gearbox tools
    skp
    skp is offline
    217
    Default DS gearbox tools
    Greetings,
    Does anyone have, or the drawings for, the gearbox tools:
    3172T
    3188T
    3174T
    We are overhauling a BvH gearbox, but having trouble re-setting the clearances.
    Stuart
    Apr 2016
    Bedford, UK
    821
    Bit obvious I guess (especially as it seems you've probably thumbed through the manuals already) - but have you looked at the technical drawings at the ends of the sections in the repair manuals? May need to look at 814 volume 1 and volume 2.
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    skp
    skp is offline
    217
    Indeed, but not of these particular tools, annoyingly.
    S
    Jul 2005
    26
    - Stuart
    It's only a little bit of help, but an indication of what you're looking for is here:
    https://www.yumpu.com/fr/document/re...-citroworld/23
    GreenBlood likes this.
    8,250
    Quote Originally Posted by skp View Post
    S
    No Drawings, but at least images of those tools - I hope someone here has them 3172T doesn't look like an easy manufacture even with tech drawings. . .
    http://ptiket2ride.free.fr/dossierPDFs/OFC.pdf
    Edit: Nigel beat me to it
    08 C5 X7 HDi very Noir
    Apr 2014
    Phoenix, Arizona USA
    699
    Do you already have the tool for setting the pinion depth 3170-T? This is a very critical dimension to get right. If you don't have the tool, you can make one from a piece of 80mm ground shaft with a transverse hole for a dial gauge to go through. Use a gage block on a layout table (or a glass table) to zero the dial indicator and you are good to go. I would have posted a photo of the one I made, but it's 600Kb......
    John T.
