' 04 C5 immobilizer fault
Results 1 to 7 of 7
  • 1 Post By dimistyle
Thread: ' 04 C5 immobilizer fault
    Aug 2016
    Sunshine Coast, QLD
    933
    Default ' 04 C5 immobilizer fault
    Yeah yeah everyone Carlo5 strikes again. Wife dropped off child 1 at school turned off car. Jumped back in started and re parked. We to start no joy..immobilizer fault appeared.
    Talk her through key re sync and BSI reset in front of other parents waiting for the carpark...no joy. Car left all day.
    I arrive lock and unlock a couple of times so central locking works. Key in to accessories went to re sync beep heared. Lock and unlock car started 1st time.
    Drove home went for a drive parked up.
    Attempted start 1st time no problem 2nd to 100th time immobilizer fault.
    Diagbox is not working as unable to activate thats another story.
    So throw me some ideas while Carlo5 sits patiently
    8,236
    Hey Dimi,
    Clutching at straws but I'd eliminate the easy things first. . .
    New battery in the key fob?
    08 C5 X7 HDi very Noir
    Aug 2016
    Sunshine Coast, QLD
    933
    Battery in fob only required for central locking.
    I'm going out to give the car battery a charge as now getting all the wonderful ESR/ Wiper fluid/ gear fault which indicates battery is on it's way out from others experience.
    Let see what happens. 😢
    dmccurtayne likes this.
    Aug 2016
    Sunshine Coast, QLD
    933
    Seems to be the car battery was causing the issue I'll re test again.
    Aug 2016
    Sunshine Coast, QLD
    933
    Has been working just fine for last few days I'll get the under warranty battery tested and check alternator output tested and report back
    Aug 2016
    Sunshine Coast, QLD
    933
    Fixed, new car battery only 359CCA on a 620. Out of 2 year warranty so discount applied😀
    10,034
    Proving that the simple fix is often the right fix! Good result.
