CV Boot change 2CV6
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By Ken H
  • 1 Post By Ken H
Thread: CV Boot change 2CV6
    Feb 2011
    230
    Default CV Boot change 2CV6
    I have the 32 mm socket and the boots , What else is needed ????
    Ive got the ties for the boot and the grease
    I have the split pin , and breaker bar
    Aug 2002
    Sunny Melbourne
    18
    I find side cutting pliers are very useful for dealing with split pins.
    A stand to put under the front hub when doing up and undoing the 32mm nut is very useful.
    Generally speaking, the breaker bar needs to be fairly long to reach the required torque.
    I think thats all you need.
    Ian S
    Feb 2016
    North Yorkshire
    109
    Regarding "What else is needed?"
    Maybe someone to put their hoof on the brake pedal whilst you're undoing and refitting the driveshaft nut?
    Both of my children supplemented their pocket money with such chores...
    p.s. A 3/4" drive breaker bar and socket are a worthwhile investment when you're dealing with 35 to 40 kgf.m torque.
    Ian S likes this.
    Feb 2011
    230
    Default Hi
    Quote Originally Posted by Ken H View Post
    Do you know why it needs 250 to 290 foot pounds of torque to tighten it ?
    Jul 2013
    Newcastle/ central coast
    2,222
    Big nut with coarse threads
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,474
    Are you just replacing the outer drive shaft bellows? You should be able to do that without removing the wheel nut. From memory, I just unbolted the inner driveshaft from the disc brake, slide it off the outer shaft, removed the Ligarex clip and the old bellows, cleaned the hub, used new grease (usually comes with the bellows), attach a new Ligarex clip if you are ambidextrous and can work out how Ligarex works or cheat as I do and use a screw clip. When done, connect the outer driveshaft to the inner one, maybe replacing the central bellows and even the inner bellows while you are up to your elbows in grease.
    John
    JBN
    JBN is offline
    8,474
    If all else fails, read the Haynes Workshop Manual, Chapter 8, Front Axle and Front Suspension, page 138, section 11 - Driveshaft Bellows - renewal (outboard joint).
    John
    Feb 2016
    North Yorkshire
    109
    Never been called that before, but can live with it...
    Anyways, a 0.5m long bar with my full weight (80kg) on it seems to have worked OK for the 39 years that I've been working on these little contraptions.
    The specified torque for the bush nuts which retains the wheel bearings is identical, as is that for the rear hub nuts.
    Quote Originally Posted by dmccurtayne View Post
    Wheel bearing fitting by slcchassis, on Flickr
    Ian S likes this.
    Feb 2011
    230
    Thanks John
    Good suggestion
