C5 X7 fault displayed
Results 1 to 9 of 9
Like Tree3Likes
  • 2 Post By dmccurtayne
  • 1 Post By k eeles
Thread: C5 X7 fault displayed
    South Australia
    69
    Default C5 X7 fault displayed
    Morning Citroenians
    Yesterday when returning from an outing the car threw up a fault with the park brake, & then ABS ESP, I know that the rear brakes were getting close to a rotor & pad replacement, so I was speculating that it may be connected (bad pun I know) to this, if I get the brakes replaced will this fix all issues the faults have identified??
    Thanks in advance for any help.
    Jul 2013
    Newcastle/ central coast
    2,222
    Did it occur when you were starting or driving along , pads shouldnít cause any problems like this , I would be thinking the battery is going.
    Garage C5 X7 3008 XTE
    Fix it right the first time
    GreenBlood and UFO like this.
    Garage C5 X7 4008
    10,128
    The handbrake for X7 is on the rear wheels. There is an off-white plastic spacer on each side at the wheel end of the cables and they collapse in time. Maybe, have a look in case yours need replacing.
    South Australia
    69
    Thanks Guys
    I have booked in for Wednesday for brakes as well as diagnostics of fault, will ask them to check for the plastic spacers.
    Jul 2015
    Ipswich
    62
    Mate, please keep us posted...but I reckon dodgy battery is likely. I have an X7 and haven't struck this (well, any issue TBH) so it would be good to know! My brakes where worn and I had them replaced but no issue similar to what you have outlined, just the old school squeeling to t osay "time to change".
    South Australia
    69
    I will keep you posted.
    Fellow Frogger! k eeles's Avatar
    Jul 2005
    Buderim
    142
    I've had a couple of strange "problems" with my C% X7 and daughter's Renault Scenic. In both cases the battery was beginning to fail just before it threw the towel completely. Such as 'depollution system faulty'; ESP and some other strange message.
    New heavy duty battery and no more messages. Kevin
    UFO likes this.
    CitroŽn Tragic UFO's Avatar
    9,791
    As others have implied - failing battery. If it was winter the car would start but run like an asthmatic dog until warmed up.
    Weird warnings have been the indicator for two battery replacements on mine. If you think that's strange, you should see the Xmas lights show of an XM when the battery is near death!
    South Australia
    69
    Just an update
    The rear brakes & rotors have been replaced plus a brake harness & switch in the dash somewhere, which seems to have solved the issue, however on the day prior to taking in the car for repair the problem made itself scarce, indicating that the old harness was indeed starting to deteriorate.
    Thanks guys
