bx trnsmission
Results 1 to 7 of 7
Thread: bx trnsmission
    Dec 2001
    37
    Default bx trnsmission
    yesterdy with out wrning , car went out of gear(automatic trnsmission).
    Car drivs OK for 500 meter then disconects (like idel!).
    revers is OK.
    IF engine is turned-of - & after 3 min restarted and put in drive,
    will drive ok for 300-500 meter and then disconect.
    Oil is Ok.
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    How are you checking your oil level?
    The same way as you check your engine oil?
    Alan S
    Dec 2001
    37
    Default no
    Engin oil- when cold.
    Transmission oil- after drivig engin on!
    8,923
    Quote Originally Posted by JLavi2002
    In "neutral" or in "park"?
    Alan S
    Dec 2001
    37
    Default in park
    In park
    8,923
    In park
    BINGO!! Should be in neutral, engine running, transmission warm & immediately after a run and/or after putting in & out of drive a few times.
    My guess is it's low on ATF but is showing OK if that's the way you're checking it.
    It doesn't sound like bands a they usually just slip like a worn clutch.
    I'll bet at least a litre of ATF will cure it unless the pump is worn but they usually don't die all that quick.
    Alan S
    Dec 2001
    37
    Default So far so...
    Thanks Alan.
    I am perplexed!
    For 5 years I have been chaking...in "parking"
    Well ...I added about 1 kilo & tested the car on 1km drive- it worked ok.
    Tonight we will drive bout 10 km and see ..
